Videos of espresso extractions - Page 5
Postby LeoZ on Sat Aug 05, 2006 1:41 pm
my 3 part addition to this thread..
First is my old krups machine, with 'not fresh' beans, and ground a few days prior at the store where i used to buy them. boy have i come a long way!
i troubleshot the terrible extraction to be from stale beans.
i dont have a good vid cam, so these are all from my camera, no sound either :/
LeoZ
Postby LeoZ on Sat Aug 05, 2006 1:43 pm
next, we have the same old machine, with a new (tranquilo) grinder, and fresh beans.
when people say get a grinder before a machine, they are not kidding!
[youtube]http://www.youtube.com/watch?v=WtkcwdIKmDI[/youtube]
LeoZ
Postby LeoZ on Sat Aug 05, 2006 1:47 pm
and finally, the newer machine, (a giotto premium, about 2 months old) with the new grinder (the new quickmill model), and a new triple basket and bottomless PF. lots aof variables! This was not only my first shot out of a naked pf, but also with a triple basket! its near perfect as far as timing, but there were some bubbles in the crema, and it did blond a bit quick. all i can think of is that the beans are fairly old, about 3 weeks, and were frozen for about a week. fyi - this is a vivace dolce bean
the good news, all my worrying was pointless, my obscure distribution and tamping technique seems to work, especially since ive had better looking dry pucks, so i didnt expect the best pull :)
LeoZ
Postby the_deal_maker on Tue Aug 29, 2006 4:43 pm
Just FYI, no more comment on the Dalla Corte at this time:
I used about 9gr of a wood fire boasted blend from a small roastery based in Venetian.
Best,
- Malte
the_deal_maker
Postby edwa on Mon Oct 02, 2006 10:18 am
... merged from espresso estraction by moderator...
A couple of days ago I received my newly purchased bottomless PF and Mazzer Mini. Very soon after I stopped using the 3 cup basket as the repeated tastings were making me shake :D The 2 cup LM basket seems to work fine.
What I soon discovered, besides how much improvement my technique needed, was that in order to really judge a pull I needed to video it. Talk about another can of beans! It took me 4 attempts to figure out how to properly light it. Then it was that I forgot to one thing in the sequence of videoing or one thing in the sequence of Silvia prep.
All the while trying to adjust to the new grinder and PF.
Excuses aside, I've registered with google video and at present their server is having trouble uploading the clip. I'll try again tonight to post the first usable clip that doesn't have a camera bump or a missed beginning, etc, etc.
The shot itself is not so good. I've gotten little momentary jets now and then. The first pulls before video taping were the best, of course. :lol: But at least the only direction is up.
For now, here's a photo of the lighting setup which unfortunately makes access to the Silvia a little difficult.
edwa
Postby edwa on Mon Oct 02, 2006 10:49 am
Let see if this comes through...
edwa
Postby edwa on Mon Oct 02, 2006 1:28 pm
Dan, thanks for posting the clip in the right thread. Its nice to see how it came out.
I see I should shoot it tighter and maybe I'll get some better focus. Perhaps a touch less light and then I can concentrate on getting a good extraction.
If this had a mid-basket fill, stirring and gentle PF tap on a rubber mat followed by a full fill, stirring, settling tap, gentle ...uh motion that resembles coin wobbling to stop, followed by 32 lbs (on a scale) tamp.
Should I make the grind a touch finer or first go for the finger press before the settling coin movement.
After, that is, I have a good laugh at myself.
edwa
Postby HB on Mon Oct 02, 2006 8:14 pm
Nice job lighting the underside of the group. How much wattage are those small lights?
As for the video, let's take a closer look. Keep in mind that this thread is about diagnosing problems, so I've excerpted several key frames for easier reference. The trouble begins early in the extraction:
A full stream has already formed near the handle and beading has only begun elsewhere. Channeling near the front is typically due to uneven distribution as you unconsciously "work around" the handle. It can also be caused by an aggressive lock-in as the group slices the top of the puck, but based on the speed of the development near the front, I'll bet on uneven distribution.
Later we witness other evidence of problems:
It's difficult to see the thin line in this individual frame, but in the video it's easy to spot at least 2-3 distinct fine-mist sprays. This could be side-channeling due to loss of puck-basket adhesion or again uneven distribution opening up small fissures. The white backdrop also shows signs of spattering. In a proper bottomless extraction, there is no overspray.
Finally, I'll zoom on this last frame to point to another sign of an uneven extraction:
Some color variation is expected and desirable ("tiger striping"), but this blond streak has the look of a localized loss of puck integrity. Though it doesn't show up until later in the video, colors twisting like a barber pole are another sign of channeling / uneven extraction. In some cases the fissures are bad enough that the stream shape itself will twist (not just its colors). It is hard to judge given the lighting of the video, but it looks like serious blonding began around the video's 19 second mark.
As you've read in your other thread, Silvia has a reputation for being finicky:
another_jim wrote:I'm no expert on the Silvia; I just got a pair in order to set up an espresso tasting lab. From what I can see so far, the machines have a huge tendency to center channel and underextract the basket edges, at least when using my usual dosing and tamping techniques which are designed to prevent side channeling (the much more common problem on E61s and the Elektra). The result so far has been distinctly inferior tasting shots, both for flavor and for mouthfeel.
I'm pretty sure one can compensate for this by modifying ones ritual or blocking some holes in the middle of the shower screen; but there's no doubt that going to an E61 or other machine with a well engineered group is a good sized step up in terms of everyday, gyration free consistency.
That said, you can absolutely pull good shots on Silvia, but she's a harsh mistress. I recommend starting with the WDT to cure the distribution problem and reviewing the Troubleshooting Checklist of Perfecting the Naked Extraction.
Postby cannonfodder on Mon Oct 02, 2006 8:27 pm
Give this a try...
That is more like a 60lb tamp. If you use 30 or 70 pounds, the key is be consistent.
cannonfodder
Postby LeoZ on Mon Oct 02, 2006 8:39 pm
im a fan of the twist n tamp. i do a light tamp with 'nutation', then a hard, 30-40lb tamp, with a twist.
anyone else?
LeoZ
PreviousNext
Return to Tips and Techniques
