tester2006 wrote:Trying to resolve poor espresso extractions, reading several topics about the brew head pressure, spraying water during the wiggle flush. I am not experiencing that. I am beginning to wonder if I have a defect machine. If I place fine ground coffee in the portafilter, it will not push water through the grounds and out the portafilter?
The gauge indicates 1.2, but the water just drizzles out with the portafilter off and lever activated, is this normal?
Thanks
There's a drill to go through when starting up an HX machine
1. Is it hot or is it false pressure? Open the steam valve, if the boiler pressure drops to zero, you have falsie pressure
2. Have you let the machine warm up for an hour -- this is not some toy, it's meant to run 24/7 or be turned on and off once a day on a timer
3. Run the pump, the water should come out boiling. Let it flush till it stops boiling, plus another 3 to 4 seconds. Now you have proper temperature
4. Do you have a commercial grinder. If not sell your machine, and buy a decent grinder -- the grinder comes first.
5. Pull shots. You're looking for about 1.5 to 2 ounces in 25 to 35 seconds of flow after the pressure ramps up for roughly 10 seconds (it's the other gauge for pump pressure) When the shot is flowing, it should read between 8 to 10 bar.
6, If your coffee is over 2 weeks old, don't expect crema.
7. Practice, practice practice
8. Read the content on this site carefully. Avoid posting questions until you are up to speed. Every question you post has 100s of people reading it, even if they don't answer, you've wasted several hours of people's time. Have both the courtesy and enlightened self interest to use your own time profitably by learning the ropes first rather than wasting every one else's time and learning nothing for it.
