cafeIKE wrote:
Try side2side shake, WDT then gentle vertical tap of the PF ring / handle junction on the edge of the counter.
The side2side shake is more like a vibration.
buzzmc wrote:The video's 49 sec, seems as though you can see the start of espresso hitting the bottom of the PF around 40. Long, short, indifferent... The pull was a little worse than normal, and I imagine I need to get closer to show some of the other possible problems.
The quick blonding on the left side for example isn't really normally lately. But the way the pour started, and the 2 streams, is fairly often.
buzzmc wrote:I'll have to get back to being exhausted with mediocrity before I go into getting a scale and such.
hperry wrote:And dosing by eye often results in more than a 1 gram difference. My shots improved immeasurably when I started weighing, and, of course, different coffees require different weights. Suggest you get a good scale that measures in 1/10 of a gram.
Psyd wrote:A scale is really nice, of course (I use one every shot, soo... with as many grains of salt as you need) but fairly accurate doses can be had by using the ground coffee. Using the same technique every time, distribution that results in a slight mound over the top edge of the basket, and then leveled with a swipe of a flat edge (knife back, chopstick, credit card, whatever) will result in a much smaller variance than measuring the beans before grinding. My results have been easily +/- .2g
