Hello Eurodolf
--Stefano has much the right of it, weather here is swinging extremes from dry to damp. A couple hours will make a large difference in humidity and the corresponding difference in grind and brew.
--Another time when I had similar problems, they went away when I cleaned my group and dispersion screen. Backflush with cleaner if possible and add a couple rinse flushes.
--Stale grounds in the grinder burrs will cause taste problems. Does your grinder need a cleaning? Have your coffee bean origins been changed, I have occasional poor batches of roasted beans when I roast. I have had some that were less than good from other roasters but maybe only once a year. Minute Rice® or a similar type
precooked rice will help clean the burrs. You can use some old beans afterward to get most of the white fines out. The remainder won't affect the taste much before they are gone. Grindz is good also!
Another take, is that anyone will have an occasional bad week or so before getting back on track.
my1¢
-Richard
