Using a tool versus a finger for distribution/leveling - Page 2
Postby BradyButler on Wed Sep 29, 2010 9:25 pm
It depends on how straight your finger is. Mine's pretty straight. I've done lots of scale work and find that using my finger for leveling is capable of dosing consistency equal to a straightedge.
One advantages of your finger is it's almost always handy... Sorry :) If you are making drinks it should be clean already. Plus you can easily updose or downdose to varying degrees using the same tool. Also, its rounded edges are less likely to drag ridges into the top, which I've observed with some items (like the doser lid). Plus its free :).
Other tools are great. I use my finger. Whatever works for you.
LMWDP #379
Carolina Espresso Services - "Quality Service for Espresso Equipment"
BradyButler
Postby spiffdude on Wed Sep 29, 2010 9:29 pm
Thanks for all you replies, i believe i've got all i need to soldier on ;-)
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
spiffdude
Postby alyce on Thu Sep 30, 2010 1:33 pm
There are several WBC competitors skipping both the distribution and leveling. It could work with a VERY precise grinder and eye and control to get it even, but yes, it's possible. I have crooked fingers (arthritis or whatever its called in english) and level with the back of my hand. Took a bit of practice to achieve a consistent result (ie. using the same spot each time as it is slightly curved) but level is the same each time.
alyce
Postby RickB on Wed Oct 06, 2010 4:42 pm
Another simple, fast and reliable method is stirring the grind with a needle. I use a long, 0.8 mm needle with a slighty blunted tip. Dosing, stirring, tamping. Works fine for me.
RickB
Previous
Return to Tips and Techniques
