Upgraded to Rancilio Silvia/Rocky - sink shots half of the time - suggestions?
Postby jjs_graphics on Thu Dec 18, 2008 4:47 pm
Hi All,
I've read quite a few posts here and there is a wealth of information available. Some background. I just recently upgraded to the Silvia/Rocky from a Breville800ESXL piece of junk. The only thing going for the Breville was that it had a HX instead of a boiler which was nice for those early morning shoot and go coffee's (wasn't espresso by any shot of the imagination, but OK coffee)
I do have a real quick question about grind fineness, dosing, and tamping. I'm using some locally roasted beans that are about 5-7 days old. I've pulled maybe 20-30 shots so far form my new Silvia/Rocky combo with very mixed results, and have "sink shot" about 50% of those.
I'm wondering if I'm not grinding fine enough? On the stock Silvia double basket, I grind about 9 up from "true" 0. (which happens to be 9 on my Rocky). WDT the grind. Level off with a knife, and tamp at around 30-50lbs force with a flat bottom RegBarber 58MM tamper. I haven't actually checked my tamp weight, but I'm sure it's pretty hard. If I go any finer on the grind with the same tamp I choke the machine.
My shots are in the 25-30 second range for ~2oz liquid, but they start VERY dark, and blonde very early (after about 5-10 seconds) I've tried numerous "Surfing" techniques on this machine, and the pulls all seem to be about the same. Very dark beginning, and blonde after about 5-10 seconds. The coffee is also pretty sour. There is good crema in the cup, but I think this is more a product of fresh beans, than proper technique.
Should I fine up the grind and tamp with less vigor? or are there other major issues here that I'm missing?
Any suggestions appreciated.
jjs_graphics
Postby Randy G. on Thu Dec 18, 2008 5:50 pm
Get out the scale and "weigh" the tamp. A very hard tamp could be masking a too-coarse grind.
Go to my website and read the "How To" article #12 in the right-hand column. Well over 10 pages of typed information aimed at helping the home barista get better espresso and solve problems.
Also check the temp surfing instructions and the how to check brew temp article, again, all in the right-hand column.
Espresso! My Espresso!
Randy G.
Postby D.Sweet on Thu Dec 18, 2008 6:46 pm
I really don't know much about roasting techniques so i might show some ignorance here, but might learn something also.
Could roasting technique affect the quality of a shot? i am sure the answer here is a complicated yes, but my question is more attempting to figure out what is different between a "regular coffee" roast, and an espresso roast?
The coffee i first put through my silvia did not give me anything that resembled even the worst shots i am pulling currently. The coffee was fresh, and from a local roaster, but was just not the same quality as what i have been ordering from Intelligentsia, and Counter Culture.
Just a thought.
Randy may be more right with the temperature angle. I know i had a lot of problems dialing my machine in along with my grinder. I bought used which was half of my problem. I also took a digital thermometer apart, and screwed the wire to the top of the boiler. My own Ghetto PID.... Well not a PID, but a good way to read temp from the top of the boiler.
I am getting pretty good results with pulling shots around 212 to 215
-Donovan
D.Sweet
Postby chuckl on Thu Dec 18, 2008 9:22 pm
I'm not sure, but 9 seems awfully high for the true zero (where the plates come in contact). Mine's at around 3, and I end up grinding at around 10 or 11. Just for the hell of it, have you tried grinding at around 10/11? The other variable that I've found to be critical with Silvia is water temperature. I've given up on following the light at all. Instead, if I'm making a cappa, I turn the machine on, let it heat for 15-20 minutes and run some hot water through the boiler. I switch off the hot water and press the steam button and let it heat for another 7-10 minutes or so, then steam my milk. I then grind my coffee, tap and tamp. but before attaching the portafilter, I turn on the brew button and pour a blank shot to bring the temperature down a little. Then I attach the portafilter for about a 27 second pour. I've had pretty consistent results doing this
chuckl
Postby jjs_graphics on Thu Dec 18, 2008 11:46 pm
Thanks all for the advice. I tried a couple things tonight just to see what would happen. I didn't end up drinking any of it, but did a lot of taste testing.
I ended up going through a quarter pound of coffee, but here's what I did..
I ramped the grinder down to 5, did a light 30lb tamp.
Machine choked
Moved grinder to 6, did the same 30lb tamp.
Machine choked
Moved the grinder to 7, same 30lb tamp.
Machine choked
Moved grinder to 8, same 30lb tamp.
pulled a very slow 1oz. very dark and bitter
moved grinder to 9, 30lb tamp.
Pulled 2.5oz in 20 seconds, early blonding
Modded grinder
Moved grinder to 8.5, 30lb tamp
Now we're getting somewhere. 25 second pull. Lots of dark crema.. still a little sour.
OK, so now I'm in to temperature issues, more than getting the grind and tamp right for flow rate. That's still going to take some practice, but making the rocky stepless, and going to 8.5 with a 30lb tamp seems to be doing the trick with this batch of beans.
On the beans, I had a shot at the local roaster and it was VERY good. they were using a La Marzocco/Mazzer setup and he pulled a beautiful naked shot in front of me. (sounds sinful, tasted better) I purchased a pound of the same beans he was using, so i don't think it's a bean issue.
A few investments I'm looking into are going to be a naked portafilter, and a La Marzocco double or triple basket. I find there's very little room with the stock silvia basket for dose amounts and errors.
Thanks all for the advice. Will keep you posted on how i'm progressing =)
jjs_graphics
Postby cannonfodder on Fri Dec 19, 2008 6:56 am
Sounds like you may have some less than prime condition coffee. Early bonding could be coffee that is too fresh and is producing an excess amount of CO2, or coffee that is past its prime. Does your roaster stamp the valve bags with the roasted on date?
I believe the Silvia comes with the OPV set pretty high as well but without a portafilter pressure gauge you cannot reliably adjust it.
cannonfodder
Postby zin1953 on Fri Dec 19, 2008 11:32 am
jjs_graphics wrote:. . . it had a HX instead of a boiler
zin1953
Postby jjs_graphics on Fri Dec 19, 2008 11:49 am
Breville Website
Used a Thermoblock Heat Exchanger instead of a boiler. I think it's probably one of the least expensive machines that actually had this feature at a $400 retail. Although temperature control on it was pretty bad, it did heat up VERY fast, and had so-so steam performance. you can get decent micro-foam on this machine, but it takes a lot of patience and practice.
Anyhow.. Pulled a couple shots on the Silvia this morning, and they are definitely getting better. I've been pulling into shot glasses to see exactly how the crema progresses, and it's looking very good. Guiness effect and all, if not always the right colour. Flavour is improving as well.
jjs_graphics
Postby jamhat on Fri Dec 19, 2008 11:50 am
Zin1953, I think it was probably a thermoblock - sometimes confused with HX.
jamhat
Postby D.Sweet on Fri Dec 19, 2008 3:08 pm
Without spending the money on a PID you might want to think about the "mini" mod that i mentioned above. You do not have PID control over your temperature, but if all is done right you will be pulling shots at least with consistent temp at the top of the boiler. Temp coming from the group head will vary a bit, but at least it is a cheap way to actually see what is going on temp wise.
The dig thermometer i used had a swiveling head. I cut the plastic at the top of the probe off, and was then able to remove the casing for the probe. I then screwed the section of exposed wire to the boiler. I screwed it in-between the two retaining brackets that hold down the thermostats.
This has been working great for me. My problem now is trying to figure out what temperature reading at the top of the boiler gives me the best shot quality. Still getting a little bitterness/sourness on most shots though.. But the shots i pull are consistent. Just not consistently great...... yet.
-Donovan
D.Sweet
Next
Return to Tips and Techniques
