by TrlstanC on Wed Feb 06, 2008 11:13 am
I've been meaning to make a post about a similar tamp vs. no tamp surprise. I was curious about the effects of preinfusion, and after playing around a bit pulling shots ended up dosing, leveling and tamping, but instead of locking in, and pulling a shot, just pouring a couple onces of water in to the portafilter - just to get an idea of what was happening. I then dug around in the wet grounds with a toothpick to see how deep the water penetrated and if it soaked in evenly or not. I then did the same thing, but without tamping, just dosing and leveling.
The surprising result was that the water in the tamped shot soaked through noticeably further then the untamped, the opposite of what I was expecting. The tamped grinds were wet about 1/2 way through, maybe more, and the untamped grinds were always less then 1/2 way soaked through. I tried it out a couple times, keeping the dose and grind consistent, and got the same results.
A few theories on what was happening:
1. It was just a freak occurance.
2. The tamp 'locked in' some bad distribution and allowed water to seep down through little channels
3. The tamp 'locked in' the distribution of the fines in the puck, while the fines in the untamped pucked all got funneled down and clogged up any passages through the grinds.
After inspecting the grinds from my grinder (Gaggia MDF) I'm guessing that option 3 is most likely. After sifting a dose of ground coffee it was clear that there were a decent amount of fines. Now I'm wondering if this could be one of the advantages of conical grinders, if the way that they initially shear the beans down to grinding size may prevent the creation of a lot of fines, and that gives you a more consistent puck, and shot.
