Turn your French press into a French pull - Page 5
Postby tinseljim on Fri Oct 30, 2009 6:49 am
I just realised something - something everyone else has already noticed probably!
If the spout was 1/4 the way up the FP with more FP body above it then we wouldn't have nearly the mess with the FP pull. Instead all the grounds would go up top. Something like this:
http://www.panik-design.com/acatalog/St ... e_Pot.html
But with a FP plunger installed.
Would this work?
James
tinseljim
Postby sweaner on Fri Oct 30, 2009 8:29 pm
Interesting. It looks like the press from this one could fit that pot:
http://www.panik-design.com/acatalog/St ... n_2d01_2d3
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby cannonfodder on Sat Oct 31, 2009 10:50 pm
Interesting. A coffee pot with a bottom pour spout instead of a top mounted spout or lip like a carafe. You could pull the plunger to just above the water line and decant your brew without having to pull the plunger all they way out..
cannonfodder
Postby tinseljim on Sun Nov 01, 2009 8:08 pm
I know right.
But how do we get it below £159/$260 ?!
tinseljim
Postby dialydose on Thu Nov 05, 2009 3:02 pm
For similar results, with less mess and work you could use the Clever coffee maker. Sweet Maria's sells them for about $12 and they make an awesome cup of coffee.
dialydose
Postby Psyd on Thu Nov 05, 2009 5:42 pm
tinseljim wrote:Would this work?
I see serious problems with water/coffee/grounds being ejected at worst, or grounds being 'stored' there until the first pour, at best. Either when you push or pull.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby The_Left_Hand on Thu Nov 05, 2009 6:07 pm
Psyd wrote:I see serious problems with water/coffee/grounds being ejected at worst, or grounds being 'stored' there until the first pour, at best. Either when you push or pull.
Espresso Sniper
One Shot, One Kill
LMWDP #175
A slide to close off the spout until it's needed would work handsomely.
—"What's sleep?"
The_Left_Hand
Postby Gime2much on Thu Nov 05, 2009 6:18 pm
Anyone mentioned the Bodum Tea press pot? The basket for the tea leaves/ground tea is removable after steeping and you can forgo pressing if you want. I'll try a pot later tonight and test it out.
Personally I prefer my press pot just the way it is otherwise would make vac or pour over.
Gime2much
Postby cannonfodder on Sat Nov 07, 2009 10:45 am
I have seen those Bodums before and thought about that. Some of the tea kettles have a sleeve that sits in the top of the pot. Think pasta pot with the mesh liner that goes in a large pot of water. You could fill the inner sleeve with coffee, fill the pot and let it steep. The few I have looked at had a pretty large screen made for whole leaf tea. If you tried using it with ground coffee, I think you would end up with a pot full of sludge. It looks like a lot of the coffee would float out of that tea sieve.
cannonfodder
Postby JohnB. on Sat Nov 07, 2009 12:19 pm
I think the Hario Mitzudash water brew pot would make a good Press style brew.
I bought mine during the summer & have only used it for cold brewing so far but it is rated for hot liquids.
I have used the Finum Brewing Baskets brewing right in my travel mug or a carafe. Same grind & steep time as press pot but the grounds lift right out when you are done brewing & no bitterness.
LMWDP 267
JohnB.
PreviousNext
Return to Tips and Techniques
