First: decided I want the vario-e when it comes out, so I'm sticking with the virtuoso until something like end of july or whatever. In the meantime, I continue to play around with the twist, practice latte art, etc. It's fun.
I have now tried a number of coffee places with espresso, and I think I'm very close with mine, as a number of them seem to be a little sour, but they have a "balance" of sorts between sour and bitter which I can get - assuming the grinder will fix this. If my shots are bitter, it's only in aftertaste, and it's the acrid kind at the back of the throat like you get with eye drops that sting in the eyes and the taste goes down nasal passageways into the throat. Unpleasant.
Anyway, I've got down a decent consistency with a Brazilian coffee from Portola on the twist and my virtuoso. But I ran out, and had some "Tanzania Edelweiss" from intelligentsia freshly frozen a couple weeks ago and dethawed overnight, thought I'd give it a try. Over the last three days (two double shots each day) At the same grind (12) of the Brazilian, I got a major gusher... shot in 15 seconds - the taste wasn't as sour as I thought, kind of creamy, and temperature wise was kind of cool. Weird and interesting. I tightened the grind a few clicks, and still same thing. Finally down to a "5" and when I pulled the trigger, took 28 seconds before first few drops started to come through. Then a kind of drippy flow came through and 45 seconds later it finished, and through the whole process, there was no "blonding" always a kind of dark, syrupy striping. The taste? Not bitter and not sour, just... like regular brewed coffee, nothing special. I opened the grind up to a "6", light brown gusher. Back to 5, and got this weird chalky syrup thing. The taste was consistent respectively. I do WDT and my tamps are level, pucks all look fine.
I'm very confused now. If I were to have a normal grinder at the right espresso setting, will the pour look like what I see on you tube with the syrupy tiger stripes in 30 seconds (right now I'm not seeing that), or is it better to go for the longer pulls with the twist? I'm too impatient to wait until end of July... grrr... hurry up baratza!
By the way, based on what I've read here, I ordered some "ambrosia" espresso blend, seems like it is a good starter, to arrive next week.
Thanks for your time.
