...[edited down the the core question]...
I think I'm having trouble dialing in my Cimbali, and want to rule out a grinder/burrs issue so I can focus on my technique.
My set-up at work: Nemox Junior & Cimbali Junior I picked up last week for next to nothing.
I'm grinding from my Cimbali into a cup on 0.1gm scales, then giving it a really good stir before spooning into the basket.
Here are a few details.
I'm extracting long enough to pull a double (50-60ml) shot.
A) dose:16.1mg, grind:6.75, extr. time:60seconds!
Expected it to taste over-extracted and bitter but if anything it was a little sour and weak.
B) dose:17mg, grind:7.0, extr. time:35seconds
Upped the dose and went a little coarser to try and pull the time down. Again no kick to it at all.
C) dose:17mg, grind:6.75, extr. time:55seconds!
Kept the dose the same (17gm gives me a little clearance between puck and screen, post expansion the puck has compressed against the screen). Again I expected C to be over extracted and bitter, but no, the sourness had gone but still no real kick.
I know my Nemox runs a little cold, the shots from my VBM Domobar Jnr HX at home are way way hotter.
I've never played with the temperature in the past, and before I got the Cimbali I had a dirt cheap Breville. Sure it was incapable of grinding anywhere near fine enough, however I was generally able to squeeze a good strong shot by overdosing to the max - 21gm+ and hand-stand tamping so I could force the portafilter on.
I'm not sure what to try next. I know it's very early to be considering a problem with the grinder, it's just that it was disgustingly clogged and when I got it, I stripped it right down and had to soak and scrub the burrs. They almost looked rusty so I took to them with a wire brush. In the end everything was nice and clean, just can't help wonder if I damaged the burrs (or they were already stuffed).
