by ppopp on Tue Jul 31, 2007 4:43 pm
Since nobody else has answered, I'll tell you how I *** think *** it's done. You'll need to pull your shot into a shot glass, or preferably a 3 oz stainless brew pitcher, because it has a spout. Steam your milk, and pour your milk into the cup. I assume you're using glass so you can see the results. Give the milk a minute to settle so you have steamed milk on the bottom and foam on the top. That's two layers. Now very gently pour the espresso through the top of the foam. The espresso should pour through the foam layer, but it will be hotter than the steamed milk below (or it should be!). If you pour it gently, it should "pool" at the top of the steamed milk layer, and a third espresso layer should develop between the steamed milk and the foamed milk.
You can do this much easier with an iced mocha or latte, with a little foamed milk on top, because the milk/ice bottom layer is so cold. This might be a good way to practice. Makes geat looking iced mochas or lattes in a large Bodum Pavina glass.
Of course you don't *** need *** to have great looking layered drinks. But it is fun.
Peter
Know beans, know coffee. No beans, no coffee.
