EDIT: After doing the following my steam wand had some pretty intense leaking while pulling shots, despite being fully closed. It has stopped leaking now, but I do not recommend the following.
Well, I have to run some more tests, but preliminary results were promising.
I tried to make some tea yesterday and came across the complaint that others have stated, it only puts out the water at about 160 degrees.
So today I tried with 6 ounces, and I applied our steaming method on the classic to tea brewing. I saw that when switching both buttons for hot water the light stayed off. I wasnt sure if that really mattered on how water mode, but I left it running with the steam wand closed for about 15 seconds, then I opened it. The temp of the water was a steady 200 degrees for the full duration.
I tried it again with 10 ounces, and it appeared that the final temp was 190. However, It seemed that the top layer of water appeared to be cooler? I need to run some more tests, but it looks promising anyway.
Any thoughts?
