How do you convert dose and shot volume suggestions for a specific coffee from 58mm to your 49mm espresso machines?
my approach originated from jim schulman's paper on extraction. there he characterizes the puck by the ratio of weight to hole area - which in a cylinder is proportional to the pucks depth. So I started correcting for the smaller area of my 49mm machine with a smaller dose. The ratio of 58mm basket area (26.4cm^2) to area of a 49mm (18.9cm^2) is 1.4. To keep the depth the same, I started dividing the recommended 58mm doses by 1.4. I also aim for a smaller shot weight (or volumes as approximation) by having a slower flow rate. What I want to hold constant by this is:
1. the pucks depth
2. the flow per basket area which equals the average migration velocity (downwards speed). For example a flow of 100ml
per minute and a 58 mm basket can be expressed as 3.8 ml/cm^2/min = 3.8 cm/min
=>1. and 2. determine together the contact time of an imaginary water package travelling through the coffee
3. the total duration of the extraction
[EDIT] ok, the whole idea is essentially useless.. unless for a comparison in the following situation:
1. one specific roasted coffee (including days past roast)
2. same grinder
3. two machines with very similar in their characteristics as for example: pressure regulation (incl. preinfusion/ramp-up time), showerscreen geometry and the depth of the brew chamber with locked in pf (max. puck thickness) ...
