HB wrote:I would say put away the timer and taste the espresso, then you be the judge.
Maybe a bit of background would help. Until I got my mini measuring glass I've been pulling (essentially) unknown volumes into espresso cups, taking (essentially) an unknown amount of time. Naturally, my shots were all over the map.
jesawdy wrote:I think the answer is... it's all good if it tastes good to you.
Yes, of course you're right. I got that measuring cup and followed my customary procedure when facing the unknown: I FREAKED OUT.
jesawdy wrote:The PNG file you refer to is from AndyS's brew ratio thread,
Yup. I confess to being too lazy to hunt down the source. Thanks.
jggall01 wrote:a little more than 2 oz from 17g of ground coffee, and it takes around 25 seconds
That sounds about like my results so far (I use 16.6 grams).
DaveC wrote:To try and keep it as simple as possible
This may have been the mental sledgehammer that awakened me to the fact that I was freaking out. Thank you. My heart rate is nearly back to normal.
cannonfodder wrote:Try keeping notes at the beginning.
This is good advice. There's a risk that I'll backslide into obsessing about trivialities, but I can see the value of leaving breadcrumbs on my path to a godshot.
RapidCoffee wrote:oft-quoted statement from the Italian Espresso National Institute
Yeah! That's the ISO standard I was after
Thanks to all (quoted or not). Your input is appreciated.
