by malachi on Wed Nov 25, 2009 6:18 pm
It depends (sorry).
1 - there are very few doserless grinders that don't have static issues.
2 - some dosers produce very clump-free coffee and others don't.
3 - some grinders produce an even and "fluffy" grind and others don't.
Fundamentally (and this is just my opinion), the "thwack" technique is pretty much required if you want to get fluffy grounds (vital for low doses and consistency) and low clump coffee from a grinder with a doser. Doing this well requires some skill and a fair amount of practice if you want good quality and consistent shots. When done right and with sufficient skill and practice, it yields results of equal quality with far greater ease and less time than what you would get from the WDT/doserless approach.
If you have a doserless grinder, with very few exceptions you are going to need to do something like the WDT if you want to get high quality and consistent results. There are very few doserless grinders that don't produce static-charged and "clumpy" coffee. With these grinders you need some sort of methodology to break up the clumps and get even distribution of coffee within the bed. The WDT is the most common of these methodologies among home baristas. The combination of WDT and doserless requires less skill and practice to get good and consistent shots that the doser and Thwack technique, but is more of a PITA in all ways.
