Thoughts on measuring: scale vs. no scale - Page 2
Postby zin1953 on Sun Jan 25, 2009 5:02 pm
another_jim wrote:. . . I have to say that the only point where volumetric dosing becomes really accurate is when you feel the depth of the puck as you tamp.
Agreed. When I tamp and the tamper goes down just so far, I know I'm in (or out of) the "correct" range.
Thread Drift:
HB wrote:Lately I've been dropping in/dropping out baskets, so weighing becomes a necessity since my basket volumes are slightly different. Try it, you'll find that 1 gram more/less makes an easily recognizable difference.
So what happens when you turn the pf over to "thwack" it into the knockbox?
I'm with you in that -- if I'm making several drinks back-to-back-to-back -- I'll pull out the clip and drop the baskets in and out. But otherwise, I keep the clips in place and use ridgeless baskets. The spring still keeps a ridgeless basket in place when I knock out the puck.
Cheers,
Jason
zin1953
Postby cafeIKE on Sun Jan 25, 2009 5:16 pm
zin1953 wrote:Agreed. When I tamp and the tamper goes down just so far, I know I'm in (or out of) the "correct" range.
I change coffee about every two weeks and the tamp depth changes with each coffee, as does the grind and dose.
Do you have a "one depth fits all :?:"
cafeIKE
Postby zin1953 on Sun Jan 25, 2009 5:27 pm
cafeIKE wrote:Do you have a "one depth fits all :?: "
Yes.
Ian, do you ALWAYS have to be literal? NOTHING is exact. Is a 14g dose exactly 14? Is it 14.1? 14.01? 14.001? 14.000000000001????
As I wrote above, "I am in the 'correct' RANGE." (Emphasis added.)
Cheers,
Jason
zin1953
Postby cafeIKE on Sun Jan 25, 2009 6:18 pm
My tamp depth varies from about 8 to 10mm, depending on coffee. That's a ±11% or +25% from the minimum. As I aim for a better than ±3% consistency on dose, which results in a relatively constant tamp depth per coffee, if one can use a consistent tamp depth, then either the coffees are remarkably consistent or are other adjustments made?
cafeIKE
Postby malachi on Sun Jan 25, 2009 7:41 pm
another_jim wrote:I have to say that the only point where volumetric dosing becomes really accurate is when you feel the depth of the puck as you tamp
While I think that might be true for some (many?) people - it's not universal.
For some (many?) people - volumetric dosing is highly accurate, period.
("highly accurate" in this case defined as variance of +/- 0.3gram)
malachi
Postby malachi on Sun Jan 25, 2009 7:42 pm
cafeIKE wrote:I change coffee about every two weeks
Seriously?
Hmmm... Interesting question then... for most people - how often do you change coffees?
Guess I should create a new thread or poll.
malachi
Postby snaab on Sun Jan 25, 2009 9:03 pm
really interesting discussion - thanks all for weighing in. and i am sold. or another scale is about to be sold, anyway. other than the fact that scales are surprisingly cheap, i think the most compelling idea has to be that a scale gives you another way to refine technique. since this is as much science as art--maybe another interesting thread, "science vs art", that i bet would generate some heated debate--having the ability to verifiably and accurately control a key variable is pretty appealing.
snaab
Postby cannonfodder on Sun Jan 25, 2009 10:24 pm
I do believe you need one to start, or for testing. You have to have something to weigh your dose, even if it is simply a reality check to calibrate your eye. When testing a new coffee or machine I will always weigh my doses just to remove that factor form the long list of intra shot variables. I do believe that you can do without after a bit of experience. I can regularly hit within two tenths of a gram working by eye alone, often closer than that. I have a third party witness that could back that claim up as well. I would imagine a pro that pulled hundreds of shots a day would be even closer.
cannonfodder
Postby sweaner on Sun Jan 25, 2009 11:42 pm
cannonfodder wrote: I can regularly hit within two tenths of a gram working by eye alone, often closer than that. I have a third party witness that could back that claim up as well.
I can verify that! Dave was always within about 0.1g.
However, I bet the competitors at the WRBC were not even weighing the doses. No weighing AND no leveling? What is this world coming to?
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby RapidCoffee on Sun Jan 25, 2009 11:42 pm
snaab wrote:...the most compelling idea has to be that a scale gives you another way to refine technique. since this is as much science as art--maybe another interesting thread, "science vs art", that i bet would generate some heated debate--having the ability to verifiably and accurately control a key variable is pretty appealing.
Well said. I dose by volume. But a digital scale sure comes in handy for testing new gear, evaluating new coffees, or taking measurements (dose, brew ratio, basket capacity, to name just a few). Highly recommended.
John
RapidCoffee
PreviousNext
Return to Tips and Techniques
