Strangely I find the same type of audio cues in steaming milk. Milk will talk to you and tell you when it is done steaming by sound more than it will by a thermometer.
-C
HB wrote:I assume Paul refers to how the water calms down during the flush.
Koffee Kosmo wrote:View the water cascade and when it runs like an ideal coffee pour turn off
It will be spot on temperature
Koffee Kosmo wrote:It may just be that it works on my machine
HB wrote:Having written a number of reviews, I've come to recognize differing degrees of how heat exchanger-centric a particular espresso machine is. My shorthand for these distinctions are:As the last entry suggests, these categories are not immutable. With minor modifications or boiler pressure adjustments coupled with barista techniques, an espresso machine that naturally fits in one category can morph into one of the other categories (e.g, Ian's HX Heaven or 1½ Boiler).
- Dragon - key characteristics are lots of flash boiling, fast recovery, nearly zero thermal memory, and slowly rising brew temperature profile. Simply stated, after the cooling flush, the heat exchanger output is the brew temperature. Examples include the Elektra Semiautomatica, Gaggia Achille, and the Olympia Maximatic.
- Mixer - key characteristics are modest flush, medium to slow recovery, considerable thermal memory, and initial rising then falling brew profile. Unlike the Dragon, the Mixer's brew temperature isn't determined solely by the output of the heat exchanger. Other factors, such as cool water mixing via an heat exchanger injector, backflow from a thermosyphon, and the attenuating effect of a heavy grouphead temper the final brew temperature. Examples include HX E61 espresso machines like the Vibiemme Domobar Super and Quickmill Vetrano.
- Agnostic - key characteristics are small, fixed volume flush or none at all, and long thermal memory. Careful tuning of a Mixer with tweaks in the design can produce an espresso machine that is heat exchanger in name only. Examples include the Cimbali Junior and Nuova Simonelli Aurelia.
