by brokemusician77 on Thu Mar 26, 2009 1:40 pm
So, I played around with a few different doses and grind settings this morning.
Up until now I've been dosing around 18g (I say around, because until I got the scale last night, I was just eye-balling it) and pulling fairly consistent shots. This morning I tried 14g and 16g. 16g. seems to be a little closer to the right ballpark. However, to compensate for the smaller dose, I've been grinding finer, which leads to clumping.
Normally, when I pull a shot at 18g. There's a slight impression left by the dispersion screen, but otherwise the shot has little evidence of any kind of channeling, etc., and the spent puck is dry.
When I pulled the shots with a lower dose, the shots channel and go very blonde at the end. The leftover pucks are somewhat soupy (moreso at 14g than at 16g.), and there are very obvious pits in the middle and channeling down the sides.
I've been using WDT. I knock the portafilter 5 times to settle the grounds then I tamp (actually measured tamp pressure this morning and I've been using around 70lbs, which I know is far too much), twist, NSEW tamp (much more lightly), then twist the tamper 2-3 turns without exerting pressure.
My thoughts on the channeling:
1. Could be caused by clumping, meaning I'm grinding too fine.
2. Tamping too hard.
3. Perhaps my machine just works better if you updose
4. There's something else in my technique that's contributing to this.
The last shot I pulled, I dosed at 16g. ground one notch finer, followed the usual method (only I tamped somewhere between 30-50lbs, rather than the usual 70). I heard the pump go to a higher pitched whir, It took 10 seconds for the first drop to appear. It took 35 sec to get 1-1.5 oz. The shot was a little bitter, but otherwise a very nice ristretto. Dark, rich crema, nice mottling, and speckling. Made it into a Latte that was almost as good as the one I had at Cafe Artigiano last week (Minus the rosette, but that's another thread maybe).
If I haven't said it already, thanks so much for everyone who's weighed-in on my various posts. I really appreciate you.
"There's a fine line between hobby and mental illness." - Anon.
