Excellent, some reviews I can use to improve my technique! Thanks guys!
In reverse order
zin1953 wrote:There are two ways to view the video, and I apologize in advance for the use of these words because I know they are a poor choice of words under the circumstances. The first is "amateurishly," which is once sense is like saying, "Cool, man, how'd it taste?" The is essentially like saying as long as you like the way it tastes (and are content with it "as is") then it's cool. The other way is "critically," as in attempting to offer constructive technique(s) for improvement. It is in this light that I offer the following comments and questions:
Excellent!
zin1953 wrote:spending waaaaaaaaayyyyyyyy toooooooooooooo muuuuuuccccchhhhhhhhh time playing with the knife.
Made me laugh and entirely true!
zin1953 wrote:the spinning thing has to go.
for some reason the spinning seemed to cut down on splattering but hopefully with other adjustments I wont need to spin
zin1953 wrote:4) Can you explain your flush routine? It certainly makes absolutely no sense to me -- from the very beginning of the video to the on/off/on/of/on/off at roughly three minutes into the video. I don't get it.
zin1953 wrote:6) What is that sound at 4:16 into the video? It lasts for approx. 12 seconds. It's not the pump; that doesn't start until 4:29.
Well the on/off/on/off was not intentional. Basically I am trying to turn the boiler on to prepare for a shot. then once its "ready" I switch it over to steam which heats it a little more (which is the sound at 4:16, too much pressure and so there is a very minimal release at the head. I call it preinfussion
zin1953 wrote:5) Why do you lock the portafilter into place so long before you pull your shot? It was locked in place over a minute before you began the shot; some of that time you were adjusting hte camera, but some of the time you were doing your "normal" routine" -- why so early? (And what's with pulling the shot into a wet glass?)
this was simply an issue with timing, between filming and wanting to get the water as hot as my machine can make it by playing with the previously described method I missed the optimal time to pull the shot and so I had to repeat the above steps. I dont have a cup heater so I warm it with liquid maybe not the prettiest way to warm your cup, but it works...and I dont know what you mean by
zin1953 wrote:why so early?
zin1953 wrote:The shot itself seems to blonde way too early
I completely agree but dont know why and dont know how to remedy it..?
Thanks Jason as always your post are greatly appreciated!
Shadowfax
shadowfax wrote:This is no guarantee of much: I've heard that many times from people selling very poorly roasted, probably much-older-than-they-claim coffee that is useless and disgusting. I'm sure it's a little expensive, but IMO you owe it to yourself to get some really primo stuff. I would start by reading this and picking one to order and work with. The worst thing you can do as a newbie is think you should learn on [possibly cheap] local coffee. It may be good or bad, but if it's bad, you'll struggle to know if it's you or the coffee.
I completely agree, I had been buying locally because it was easier and, even though I still need improvement, my shots were so bad before that I hated the idea of buying great coffee when I was just going to through half of it out anyways.
shadowfax wrote:We eschew volumetric measurements for the most part. They're pretty inconsistent when you're working with espresso. It's best to weigh both your dose and your cup (see here).
My scale should be here tomorrow, Im hoping 1gram incremental scale is effective enough; what do you think?
shadowfax wrote:This isn't entirely true. With the WDT you are looking not just to break clumps but also to produce an even distribution in the basket. A knife may do the former, but it's very counterproductive at the latter. You need to get a much smaller tool (like a dissecting needle) that can break clumps without pushing coffee around so much.
this is actually kinda funny, I have been pushing off buying a dissecting needle because I hate the idea of spending $8 for shipping on a piece that is worth 25cents. I have tried finding it around town; I'll bite the bullet and order today though. (thanks for the motivation)
shadowfax wrote:I suggest putting your fingers around the edge of the tamper piston as you set the tamper in the basket. make sure it's sitting level in the basket using your fingers prior to tamping. This should help you out a good bit.
Regarding your shot in general, it looks to me like your shots do not bead evenly and that the center of the basket is slow to start. I think you likely have too much coffee in the center of your basket and need to press it out to the edges better prior to tamping. A better WDT tool and better NSEW or other levelling technique should solve this problem. I think your distribution/tamp need just a bit of work before you can start pulling more even shots, then you can get into more meaningful grind/dose adjustments and temperature management, where your tastebuds, rather than your video camera, will be your guide
Roger that and thank you for your time ShadowFax I will certainly implement your suggestions.
F.M Thank you for saving me from Ian's wrath
F.M. wrote:First thing I would work on is your dosing distribution. You need some better way to evenly distribute the coffee in the basket after pouring it in. Think about consistent density at the bottom of the puck, not just leveling the top. You could stir with something finer, do a leveling "thump", or something else. What I do is put an empty single basket over the basket I've dosed into, then do a leveling thump to "settle" the grounds, then WDT, then tamp.
have to admit, Im kinda curious what your method looks like...on film
. I will take your advice.
F.M. wrote:Think about holding the tamper like a doorknob, with your fore-arm vertical, and watch the edges of the tamper relative to the basket/PF as you tamp to make sure everythings even.
hmmmmm
F.M. wrote:Your shot looks under extracted to me. It could be the coffee.... but I would try 1 click finer on your grinder, or updosing 1-2g. It could be blonding early just because the water is finding the easy way around the coffee bed (likely around the low side created by uneven tamping)
I agree with you it does look underextracted but if I go any finer it chokes my machine. my second video extraction is 35 seconds or so. I will adjust my tamping and hope that is it
Thank You all very much for your time I truly appreciate it
