by RayJohns on Thu May 19, 2011 8:12 am
In my experience, grind is a lot more important than tamp. Also, in many cases, you'll find that sometimes the tamping pressure that works best is quite a bit lighter than you think. On my La Pavoni, for example, I probably only tamp 5 to 10 lbs max.
A super hard tamp generally just promotes channeling, while not really solving many other issues. Like I say, most of the magic happens in the grind, not the tamp. Grind is like 90% of it and tamp is maybe only 10% fine tuning (if that). I mean, sure, you have to have a good solid tamp. But it really should be a feel that you develop, not just a blind 30 lb click from some tamper.
Get yourself a good Reg Barber tamper and learn how to use it by feel. You'll be happy you did.
As mentioned above, having the proper tamper diameter is far more important in practical application.
Ray
