RapidCoffee wrote:Yes, that's correct (65% brew ratio). I typically weigh the coffee dose, but not the resulting espresso. The grind is adjusted to give me (approximately) a 30 second extraction. I use a 30 second kitchen timer for a reminder, but stop the pour using visual cues (shape of extraction cone and blonding).
So if I read the table correctly (ratios) the volume you collect, with crema, is slightly less than 1 oz? [Edit: Doh!!!, you had the volume in your post.]
By the way, thanks all for the discussion. This is helping a lot. When I look at most extraction videos, I do not believe that any are using the "2 oz in 24 seconds" rough guidelines I was shooting for. Two oz in 24 seconds, by contrast to the videos I have found, is essentially a gusher. My taste preferences have been towards the ristretto end of the spectrum.
