There are two schools of thought: (maybe more...but these are MY two
1) Adjust your grinder slightly coarser. On the Mazzer it equates to about 2-2.5 notches.
2) Learn to tamp by "feel". You have to tamp a little lighter on the single.
Conventional wisdom would say, adjust the grind. This will probably be the best/easiest path for the Home Barista. But at home, or at a caffe, you must make sure to clean the 'double' grounds out of the grinder--the ones that tend to hang up in the chute. If the Macap cleans out better than the Mazzer, then no worries.
Learning to tamp by "feel" is also worth learning. Unless you have drastic changes in humidity, age of beans, etc. that REALLY cause you to change the grind by a noticeable amount, you can learn to feel how the grounds in the portafilter yield to your tamping, and in turn learn how much pressure to apply. In the case of switching from double to single, this is what I often do so as not to have to adjust the grinder anytime someone orders a triple.
We don't do split shots here. I'd rather pull a good single.
