by JmanEspresso on Mon Nov 22, 2010 11:46 pm
For me, Toscano has always worked best with a bit of an updose, and pulled a bit tight.
On my machine, Ill run it 18grams. When I had an E-61, I ran it at 20gr. My point is, I cant give you an exact dose to use, because machines all like different stuff. But, on the Classic, Id probably try 17-18grams if your double basket can handle it. Just make sure you're not cracking the puck on the screen when you lock in.
As for shot volume/timing, generally Ill shoot for 1.6oz or so in about 30-32seconds. Again, play around. But, I find that the "2oz in 25sec" generally doesn't produce the best tasting coffee, especially with blends like Toscano. Usually an updose and a tighter/shorter shot works better. For me.
Toscano is a fairly easy coffee to work with, and it allows you to play around with different doses and volumes, all the while still getting great coffee as the result. So don't be afraid to go out of your normal range.
