by luca on Fri Oct 10, 2008 4:07 am
You have received some good advice and forgive me for repeating some of it.
First up, I have read that your particular machine comes with a choice of dispersion block (or whatever it's called); there is a thick one and a thin one. If you have the thick one, it will make the shower screen protrude further into the basket. Most people that I know hate machines with shower screens that protrude far into the basket, though I'm sure that it is possible to adapt. Find out if you have the thick dispersion block and if you do, replace it with the thin one.
With that out of the way, I'd just like to confirm that we're all attacking the same problem. From what you have written, it seems to me as though you are currently pulling thin and bitter shots and you would like to make them more 'strong and smooth', as you were used to. Is this correct?
Marshall has given you the best advice; getting training isn't often discussed online, presumably because once people do it they have little need to ask questions. If you pony up some dough for a half decent trainer, you will notice very quick improvements. If you want to do it yourself, you should expect to improve slowly, with a few "aha" moments along the track. If you place much value on your time and on the bad coffee that you will have to drink along the way, I think that you will conclude that a good training session is the best bang for your buck of any of your coffee purchases.
Failing getting a trainer, I would make the observation that you will only improve through repetition. Get a whole bunch of coffee and set aside an hour or two on each of your next few weekends. You might think that this is a waste of time, coffee and/or money, but I can assure you that you will learn much, much faster than if you make only a few coffees per day, with many interspersed inbetween. I would also suggest that you pick just one freshly roasted blend that you know to be good and stick with it for several months; preferably a blend that you can taste extracted properly at a nearby cafe.
Moving back to your problems with your extractions, as others have mentioned, don't even bother drawing conclusions from anything other than the shots that you have pulled using decent coffee.
In general, you can decrease bitterness by:
(a) getting better coffee;
(b) lowering your brew temperature;
(c) increasing your dose and grind size; and
(d) running your shots faster.
From reading your post, I suspect that you might have overlooked the importance of achieving a consistent dose. This is, IMHO, the most difficult aspect of espresso making, the thing that is most often the problem for beginners and the aspect that is most often overlooked. Fortunately, it is pretty easy to see how consistently you are dosing. You could always weigh each dose out; having worked in espresso bars, I find this to be irritating, fiddly and unnecessary, but I note that many home baristi swear by it. I would advocate doing a simple test:
(a) get your hands on a set of measuring shotglasses and a stopwatch;
(b) dial in your grinder; and
(c) make five shots in a row to the same volume and note how long it takes for each extraction (from pressing the button).
If you aren't within about three seconds, you need to work on your dose.
I would suggest starting with the following dosing and tamping technique; grind to a small pyramid above your portafilter, rap the portafilter against the bench twice to settle the coffee, get a credit card or similar to strike the top off, filling in any gaps on the side and then tamp once. If you want to use a low dose, don't rap to settle. IMHO, you shouldn't be complicating your routine any more unless you can establish that there is a discernible benefit. Getting a bottomless portafilter might help you to do that.
Once you have established that your dose is consistent, you can start trying different parameters. If you have a relatively dark roast and you are interested in a smooth shot and want to keep it easy, I'd start by maxing out the preinfusion time, dropping the brew temperature a few degrees, and extracting 2/3 of a traditional double shot. Something like 40mL in 20 seconds from the double basket sounds about right. If your machine's temp readout is relatively close to what's at the group, I'd suggest 91C. All of this is, at best, a shot in the dark and just a starting point.
I would also note that, from what I can tell, the LS has a group that is just a chunk of metal coming off the boiler. My old boss currently has a multiple boiler machine with a similar setup on his bench whilst his Synesso is in for repairs. He has found that the group heats up and the shot flavours change after the machine is used more and more - possibly because the group heats up. I am not sure whether or not this is an effect that you will need to worry about, but I presume that owners of your machine will quickly jump to its defence ;P
Regarding doses, there has been a bit written recently about low doses and fine grinds being easy to work with. I have tried this and I don't think that it will produce the sorts of results that you are after. I can't imagine that half filling a double basket would ever be a good idea, but I haven't used the LS single. One virtue of a higher dose is that a dosing error of the same amount makes proportionately less difference.
Hope that helps,
Luca
