Stuck learning how to microfoam! - Page 3
Postby SteamPunk on Sun Oct 16, 2011 11:54 am
Sorry to hear of Your predicament.
I own a duettoII and have found that at first the machine steamed beautiful microfoam,
but as time went on it seemed to get tempormental?
I thought it was Me, yet I knew I had the ability to produce decent foam.
Some prefer a nice thick 'paint' others 'clouds' of foam on top.
Whichever You prefer, the duettoII and I'm sure all other decent machines,
are capable of doing both.
I found to my surprise, that if You keep the steam tip squeeky clean, the machine
steams flawlessly!
I do mean clean.
I had always wiped the tip well after every use and blasted the steam to flush it
out well, I thought.
I still had to play around to finess a decent capp
I was shocked to find one day that after I cleaned out my four hole tip
with a safety pin and then soaked in soapy water,
that the machine steamed flawlessly, eveytime, with no fuss!
Just keep a safety pin handy, make sure it's not too big a size for Your holes.
Also remove tip and soak regularly, just for a few minutes, don't lose gasket.
Your problems will be solved!
SteamPunk
Previous
Return to Tips and Techniques
