by roccster on Tue Mar 29, 2011 7:00 am
Yesterday morning i did my "regular" latte. The extraction was really good, approx. 20-25 sec. When I got home later that afternoon I turned the machine on (Fiorenzato Bricoletta E61), waited for 30-40 minutes and prepared for extracting my afternoon espresso. The coffee in the grinder was the same bean as I ground in the morning. I ground the same amount as I always do, tamped it, flushed the Bric. and started the extraction. Pretty much nothing happened. After maybe 20 sec. a few drops started to emerge, and after another 20 sec a very slow extraction. I didn't wait for it to finish. I did another try and that was probably worse then the one before. A bit worried that the machine had broke down on me again I now changed the coarseness on the grinder (4 steps), and now the extraction went fine. The espresso looked, and tasted as it should.
So here is where I start to wonder. Can the roast of the coffee be so different so that all of sudden you need to change the grinder coarseness? Or is it perhaps something wrong with the pressure?
I made my latte this morning, and I had to go down a step on the grinder, still I am a bit worried though.
