by JmanEspresso on Fri Sep 11, 2009 10:58 pm
When I first got Anita, I had a lot of trouble with steaming.. I couldn't get anything but hot milk, or soap suds. So, I picked up the "Expobar Single Hole Tip", from WholeLatteLove. Instantly, microfoam was happening. After about a month or so of using that tip, I decided I wanted to learn how to use the much faster 2-hole tip which came with my machine. I watched the video by Scott Rao, about learning MF with Soap and Water. You dont have to worry about wasting milk at all with this technique. I took me probably, idk, about 45mins to get it down.. Then I tried with milk, and got it on my second pitcher. The video is easily found on youtube, but in short, fill the pitcher with as much water as you would milk, and put the smallest drop of liquid dishsoap that you can.. Literally one drop. Then, froth the "milk". It acts almost exactly like milk. In the video, its also about learning latte art, so he's got you pulling shots and pouring the soap/milk into them.. I dont see much need for that at home.
But, after I watched the video, everything clicked. Ill still use the single-hole tip now and then, but mostly when Im making a Machiatto.. For a traditional capp, Ive got the two-hole tip pretty much down pat.
Unless you are an uber-barista, everyone will have to spend some amount of time "Re-Learning" microfoam on a new machine.. Every machine has its own style which you need to adjust too.
Note: A couple months ago, I found out that I bought the last single hole tip from WLL, as a couple people were told they were sold out only days after I ordered.. I think it may be available elsewhere.. but I would Imagine WLL has them back in stock.. Its been a long while since I ordered it. Making your own with an Acorn Nut is pretty simple.. The hardest part likely is finding one with the right thread pattern.. Then you just drill a quick hole. If you go this route, id buy a couple nuts so you can try different size holes.
