Steaming Skim Milk
Postby caffe1nated on Wed May 11, 2011 5:37 pm
Ok, so I know that steaming with skim/non-fat milk is very difficult, and impossible for some people, but there has to be people that have success. Do you have any tips to try to steam skim milk for lattes and for latte art? How do you get it to the right consistency? Please don't respond if all your going to say is "Just buy 1% or 2%, it's impossible."
caffe1nated
Postby HB on Wed May 11, 2011 6:18 pm
I'm not following you; what makes steaming skim milk hard? The texture is more airy, but that is to be expected without fat. Inject very little air by burying the tip deep sooner. What am I missing?
Postby caffe1nated on Wed May 11, 2011 7:23 pm
The milk separates too quickly/or doesn't integrate at all. When I pour, I have layers--normal hot milk and foam instead of nice uniform stretched milk. Your saying add less air and sink it sooner, I haven't done that. I'll try it out and comment later.
caffe1nated
Postby Marc on Wed May 11, 2011 7:25 pm
In fact, skim milk steams way better than whole milk. It's the protein that create the foam stable and not the fat.
Marc
Postby caffe1nated on Wed May 11, 2011 7:28 pm
The problem is not that I can't get foam into the milk, I can do that. I just can't incorporate that into milk I could use for lattes/art
caffe1nated
Postby Marc on Wed May 11, 2011 7:52 pm
either your waiting too much before pouring or your not mixing it enough - which needs steam power.
Marc
Postby HB on Wed May 11, 2011 8:22 pm
Marc's right. Good steaming power will roll the milk along the bottom and back up other side like this:
If your machine can't do this, one post-steaming trick is swirling/thunking to combine the liquid and foam. The video below is one of my "cotton ball" goofs that I partially recovered from using this technique:
Technical commentary copied from another thread: For a latte, too much air was injected, though it was about right for a cappuccino. I used my largest cup (12 ounces), which drew out the espresso to a thin layer, increasing the speed with which the crema dissipated. The polishing technique seen in the first part of the video eliminated the "cotton ball" and elicited a nice paint-like texture from the milk. Pouring began high, though not aggressively enough, causing an initial splash of white across what little crema remained. I should have lowered the pitcher nearer the surface and the rocking motion was too late and not quite enough.
It helps if you use a pitcher that's slightly larger than needed. This gives you the extra height to swirl the liquid up against the sides, thereby incorporating the foam. Some find it helpful to place the pitcher directly on the countertop and move it in a circular pattern with two hands; it's easier to swirl more aggressively this way without spilling.
Postby genecounts on Wed May 11, 2011 9:32 pm
I always use nonfat milk. What kind of non-fat milk makes a huge difference, at least to me. I pay a premium at local Food City to purchase their organic non-fat milk called Full Circle. The gallon I'm using at the moment has an expiration date of June 27. The expiration of their other non-fat expires next week.
The run-of-the-mill nonfat just doesn't do it for me. It is too thin. The Full Circle makes beautiful latte art every time.
Of course, like Dan counseled, I'm using 12 ounce Espro Toroid pitcher for cappuccinos. Just two quick squirts to flush the steam arm of the La Spaz and sink it in deep for six seconds and make sure you have the stream centered. Slowly back it to top of pitcher lip in next 15 seconds.The shape of the "Toroid" insures the milk disperses in 360 degree arc and approx 21 total seconds later voila!
I don't make good art but it's just human error....getting better.
gene
genecounts
Postby caffe1nated on Wed May 11, 2011 9:41 pm
Thankyou everyone, I'm going to try to incorporate these techniques into tomorrows morning latte.
caffe1nated
Postby cafeIKE on Thu May 12, 2011 12:17 am
Assuming Silvia, as the Miele is hopeless, skim and low fat milks vary considerably.
from 2% Frothing
which begs the question why bother with adulterated milk. US whole milk is 3.4% fat or about 30 fat calories per litre. 4oz / 125ml non fat milk has less than 4 calories fewer than real milk.
It's already been shown that butter is better for you than hydrogenated oil aka margarine.
America has gone nuts on nutrition at the expense of food.
cafeIKE
Next
Return to Tips and Techniques
