by cpreston on Wed Feb 23, 2011 10:16 am
As widely suggested, I started out with a bottomless pf and eventually got good results. However, I always had trouble seeing exactly where the blonding point was (yes, I have watched the video and read the many threads on this). A fairly gradual blonding transition was an issue to one degree or another with every coffee, and it may just be a characteristic of my setup. This made it pretty hard to decide when to stop shots.
Anyway, more recently I decided to experiment with the spouted pf (same Synesso basket), and to my surprise I saw a much clearer reference for stopping shots, based on a clear point when the mouse tails collapsed inwards. It turned out to be around the same timing I had reached before with the bottomless, but it was much easier to see. With the bottomless, I generally had not seen such an obvious cone collapse moment or other indication.
I'm not saying that point is exactly when to stop a shot, just that it was a lot easier to see as a reference point than anything with the bottomless.
Based on my experience, I would use the bottomless only to check pour quality at first, and once it looks reliable, go to the spouted pf for everyday use.
Has anyone else noticed the spouted portafilter giving a clearer indication of when to stop shots? Or is it just my setup/technique? I believe I'm generally getting clean pours and good espresso with either pf.
