cannonfodder wrote:Keep in mind that the water in that puck goes from being pushed out at 130psi to being sucked up the opposite direction to 0 psi in less than a second. That will scramble the puck and make reading it just a little less accurate than reading tea leaves. Just knock it out, wash off the basket and drink your good espresso. I would recommend a quick 2 or 3 second flush to clear the shower screen after you remove the portafilter and wipe it off to get the excess debris off.
When trying to make several espressos in a row, being able to dump a puck cleanly is a plus. Having said that I agree that making crappy espresso for the sake of a good puck is not a good idea. However, the statement above strikes a chord.
I note that when using an e61 with a three way solenoid, if I take the portafilter out of the machine and dump it using a knock box immediately, the puck might be soft and breaks up on the way out. However, if I wait 3-5 seconds after taking the PF out, it typically dumps cleanly. While waiting, I can see a small amount of remaining water draining out of the puck (i.e., not enough to drip out the bottom of the PF). It seems that this draining does not occur until the PF is taken out of the group, and I suspect that the 3-way solenoid maintains some negative pressure on the water already in the puck, keeping it from draining entirely.
