by David R. on Fri Aug 13, 2010 1:15 am
"Testing purposes" is when you need to start with known-good coffee, and lots of it. It doesn't need to be boutique coffee, just coffee that is reliably fresh, consistent, and known to produce drinkable shots. (It doesn't even need to be especially good, just consistent and not especially bad.) I used to use the espresso roast from CCM Coffee for machine calibration because it was adequate and very inexpensive, but they no longer ship to my part of the world and so I do not know if they remain as consistently adequate.
Once you have that, follow any of the tutorials available across the web (including this forum) on dialing in a new machine, but keep a few things in mind. First, the MDF grinder has relatively wide steps between grind levels. This means that your final microadjusting will likely be in dosing and tamping, not grinding. Second, you can eliminate tamp as a variable by pretty much not doing it. Fill the basket with no extra compaction, level with a finger, and then tamp just enough to get the coffee even and below the level of the showerhead. (Later, when everything else is working, you can play with tamping, but for debugging purposes just go with the light leveling tamp to keep it from being a major variable.) Third, some Gaggias have shipped with weak pumps. I have two Gaggias in my closet, one has a far weaker pump than the other. For debugging purposes, do a search for "water debit".
It sounds to me that you have too much coffee, ground too fine and/or tamped too hard, for what the pump can take.
David R.
