Simulating a paddle shot
Link to "Simulating a paddle shot"by Arpi on Tue Jun 30, 2009 8:56 am
Something to play around.
The paddle GS3 CG discussion got me thinking. Apparently they got good results by using a low pressure long preinfusion thanks to the paddle lever. So I did something similar this morning.
My expobar brewtus has a very smooth water output but I don't know if this would work with all machines. I turn the pump on for 1 second and turn it off. Wait 8 seconds to soak the grounds. Then I pull the shot (~27 seconds). I know I didn't over do the preinfusion because flush water doesn't come out .
The flavor is different and if my mind doesn't do me a trick, I think it is sweeter.
I am not claiming that I get the same results as a GS3 or anything like that. Just playing.
Cheers
Quest M3 Roaster User Group: http://groups.google.com/group/questm3
Arpi
Link to "Simulating a paddle shot"by cannonfodder on Tue Jun 30, 2009 10:04 am
Interesting that you got anything drinkable from that. Simply pulsing the pump will open the 3 way valve and dump what water you did get in the group right out the valve. The rapid decompression from brew to off will also suck the puck up and destroy your coffee cake.
Your are simulating the pre infusion that the GS3 uses which is quite different than a paddle group. It pulses the pump for a couple of seconds then goes into standby while the puck saturates. Difference there, they keep the 3 way valve closed, then the pump kicks in for the full extraction. To do that on your machine, you would need to put a bypass switch on the 3 way valve so you can turn turn it off, then pulse the pump, then run the shot and turn the bypass back off so you get the pressure dump at the end of shot.
cannonfodder
Link to "Simulating a paddle shot"by Arpi on Tue Jun 30, 2009 10:28 am
No, it doesn't dump all water. I can even pull the portafilter out and watch how the remaining water soaks up the puck (~30 seconds). The water comes out very gentle from the screen, and does not destroy the coffee cake at all. It never reaches high compression because I only do it for one second. And as I said, I don't see water being flush out.
Perhaps I get that because I never fill the basket over the line. Anyway, the flavor is good.
Cheers
PS: not sure it it would help. But maybe trying a double dose in a triple basket may give you a greater time clearance for preinfusion
Arpi
Link to "Simulating a paddle shot"by danetrainer on Tue Jun 30, 2009 12:24 pm
cannonfodder wrote:Interesting that you got anything drinkable from that. Simply pulsing the pump will open the 3 way valve and dump what water you did get in the group right out the valve. The rapid decompression from brew to off will also suck the puck up and destroy your coffee cake.
Dave, the control lever of the Brewtus allows three positions, the middle position neither activates the pump nor the three way valve, so this is possible without disturbing the shot.
danetrainer
Link to "Simulating a paddle shot"by denniskeating on Tue Jun 30, 2009 12:40 pm
Hello, What is the feature of the paddle grouphead vs other styles? All I know is the "saturated head" mounts on the boiler. - Dennis
denniskeating
Link to "Simulating a paddle shot"by Arpi on Tue Jun 30, 2009 1:39 pm
Hi Dennis.
Take a look here: http://www.coffeegeek.com/forums/espres ... nes/426628
If anybody has problems with preinfusion you can try this improvised dirty trick (never actually tried). On the shot glass pour some water from the water wand. Then carefully put some of this water on your loaded portafilter and wait a few seconds till some of it soaks up the puck. Then lock the portafilter in place. You may not get exact preinfusion temp but it may help to discover the effect of preinfusion for those that cannot otherwise do it.
Cheers
Arpi
Link to "Simulating a paddle shot"by cannonfodder on Tue Jun 30, 2009 1:43 pm
danetrainer wrote:Dave, the control lever of the Brewtus allows three positions, the middle position neither activates the pump nor the three way valve, so this is possible without disturbing the shot.
Thats right, I was thinking electronic for some reason, sorry about that.
The preinfusion you get from a paddle is actually more like a lever machine with a gentle pressure ramp, if you gently slide the paddle from one side to the other. The E61 group with a vibe pump has a very gentle pressure ramp unlike most rotary machines which hit full pressure in one or two seconds. The machine essentially has a paddle group pressure profile to start with. But there is nothing wrong with playing with parameters. If you like the coffee, that is all that matters.
cannonfodder
Link to "Simulating a paddle shot"by shadowfax on Tue Jun 30, 2009 9:55 pm
Arpi,
You have a rotary pump, don't you? Are you using a water line or a tank? If you're hooked up to line pressure, you shouldn't need to activate the pump to soak the grinds. You should be able to hold the lever in the middle/slightly up position such that it opens the 3-way valve on the grinds but doesn't engage the pump, allowing water in at line pressure. That will give you super-gentle, moderately adjustable preinfusion. Pulsing the pump is probably safe, but certainly an added risk. On my T1 (which has no gicleur chamber for gentle preinfusion) I have a delay-timer on the pump so that the 3-way valve opens prior to the pump going. Similar thing. I haven't played with long preinfusion, but a modest amount certainly makes it easy to pull more consistent shots without having any negative impact on the shot that I can tell.
Nicholas Lundgaard
shadowfax
Link to "Simulating a paddle shot"by HB on Tue Jun 30, 2009 10:53 pm
This reminds me of something I posted in an old thread, The Secret Life of Ristrettos:
HB wrote:As a rule of thumb, ten seconds of (extra) preinfusion equals a grinder adjustment of two millimeters coarser on the Mazzer Mini, or a reduction of coffee equal to approximately 1.5 grams (*). Running the mega-sized preinfusion "softens" the puck and opens a wider window for good extractions. My results so far for ristrettos are improved, though the opposite occurred for regular doubles, where the flavors became muddy and flatter.
To distinguish this from Rafael's on/off approach, I refer to them as preinfusion (some pressure) and prewetting (no pressure). My guess is that the worse the grouphead's initial water diffusion and the worse the barista's technique, the greater the benefit of the "enhancement" offered by manual preinfusion/prewetting. Why designers/baristas choose to focus on correcting the problem after it's already happened rather than preventing it in the first place is another question.
PS: For those who are wondering about E61 prewetting/preinfusion possibilities but aren't following the discussion points above, see Is there a purpose for the E61 middle brew lever position? for details.
Link to "Simulating a paddle shot"by Arpi on Wed Jul 01, 2009 6:01 am
shadowfax wrote:Arpi,
The problem with that is that in the middle position I don't have any feedback and I don't know if water is coming out or not. There is no indication on the lever and cannot tell by feeling either. That location is not that obvious to get and it is very close to activating the pump. I would not be able to control the soak time unless I put my ear very close to the group head and listen to water noises. It can be done but it is harder for me.
The little added pressure of the on/off trick seems to help me more and I get a sweeter effect. I tried this morning the trick about adding water from the water wand but I think I didn't let it soak long enough and it wasn't like the others.
Cheers
Arpi
Link to "Simulating a paddle shot"by denniskeating on Wed Jul 01, 2009 12:17 pm
Hello, The way I understand it, the new B 111R should utilize a water solenoid with the pump/motor so that water will not flow thru unless the pump is switched on. I have not confirmed this with WLL, though.
This would be a safety feature to prevent floods from different users and their practices.
Arpi, in the past, some Brewtus owners reported their mid lever position allowed water to flow thru, and some reported nada. Todd responded about a part inside the grouphead that is longer on some machines, not allowing the flow thru. If your unit is one of those, the part can be replaced with the piece that works.
On my B1, I converted to external pump/motor with plumb in and plumb out. Mine is converted "suicide style" with constant line pressure, and offers the manual preinfusion feature.
I have been reminded that our E-61 semi-auto lever boxes offer the best preinfusion feature compared to full-auto models. That is a plus. - Dennis
ps - Arpi, how's your back doing? Mine has been acting up for two months, now!
denniskeating
Link to "Simulating a paddle shot"by coffee_monkey on Wed Jul 01, 2009 1:34 pm
By converting an E61 lever into the same configuration as Dennis' (with one small addition), it allows you to experiment with "Paddle/Slayer" style pressure profiling.
So you want to make sure that:
1. Your E61 lever is hook up to an plumbed-in rotary pump (with built-in bypass valve).
2. No inlet (safety) solenoid is in the chain so that you are seeing line pressure at the group head.
3. Add an needle valve just up stream of the brew head
The needle valve allows you to tune your water debit. If you do not change the gicleur, the rotary pump ramps up to full pressure in about 2 seconds. By decreasing the water debit, you can tune your machine to have that "stock" gentle ramp up (~6.5 seconds) of an vibe-pump E61.
I also recommend putting a pressure regulator at the inlet of the rotary pump - this allows you to tune your line pressure.
When the lever is at off position, the group is closed and the 3 way is open. Turning the lever about 50~70 degrees (right before it engages the microswitch), the group opens, closing the 3-way, and allowing water to flow thru and ramp to line pressure. Engaging the lever fully (depressing the microswitch), the pump kicks in and it ramps from that line pressure to the set pump pressure. This allows for several possibilities in pre-infusions.
Toward the end of the shot, you can move the lever from 90 degrees back to about 80 degrees such that the microswitch is allowed to come to the off position. This kills the pump and the pressure will ramp down (~2 seconds) and hold at slightly above line pressure (approx 6~7 bar). This is similar to what Slayer is doing w/ their machine thought their ramp might be a bit more gentle/longer due to the smaller orifice in their "pre-infusion" position.
While this does not exactly offer full control over pressure profile, this simple/cheap setup does allowed for some play potentials. I have yet to have any conclusion on the reduced pressure toward the end of the shot or the extended pre-infusion at the beginning of the shot.
Ben Chen
coffee_monkey
Link to "Simulating a paddle shot"by Arpi on Thu Jul 02, 2009 5:57 am
denniskeating wrote:Hello, The way I understand it, the new B 111R should utilize a water solenoid with the pump/motor so that water will not flow thru unless the pump is switched on. I have not confirmed this with WLL, though.
Hi Dennis.
In my B3, water does comes out when the lever is in the middle position and the pump is off. When the lever is at this position, the pressure reads zero bars and water comes out gentle. It makes a gargle boiler noise but it works. My line pressure is regulated down to 11 psi with the pump off. With the pump on, the line pressure reads 7 psi. So I guess that I would get a max of slightly less than 1 bar of preinfusion with this method. With the on/off method I read a residual 2 bars on the gauge.
I tried twice the trick of just putting water on to a loaded portafilter (zero pressure preinfusion) but did not get the same results (again). It'll probably take some more tries to tell if this is always the case.
Cheers
PS: Tomorrow I'll probably have time and I'll make a little video
Arpi
Link to "Simulating a paddle shot"by denniskeating on Thu Jul 02, 2009 11:16 am
I checked with WLL tech support (cathy), and she indicated they did not use a water solenoid to control water fl0w thru with the lever in mid position.
Some time ago, I remenber Todd stating when a plumb in was applied, he would choose a solenoid for it.
Instead, WLL stated they instruct owners to adjust water line pressure to below 12 lbs so it doesn't push it's way thru the grouphead. - Dennis
denniskeating
Link to "Simulating a paddle shot"by Arpi on Fri Jul 03, 2009 10:17 am
Hi folks
This is a little video showing first the middle position of the lever and then the upper position of the lever
Cheers
Arpi
Link to "Simulating a paddle shot"by Arpi on Fri Jul 03, 2009 10:28 am
I just tried again and I get good results by doing a 10 seconds middle lever shot followed by upper lever shot. I guess that is called a two paddle shot :)
Cheers
Arpi
Link to "Simulating a paddle shot"by shadowfax on Fri Jul 03, 2009 10:53 am
That's all well and good, but it looks like you might have a problem with water falling sideways.
Nicholas Lundgaard
shadowfax
Link to "Simulating a paddle shot"by Arpi on Fri Jul 03, 2009 11:02 am
jeje I can make it go up too.
Check this out. I turned off the machine then I went back the temp was 183. I thought...hmmm...let me try an all low pressure-coarse ground shot 1 oz. Why not?
The flavor was very different! It had no crema but I was surprised by the total change in flavor, very unusual.
Cheers
PS I made a hybrid shot. 201 F Coarse grounnds 1/2 oz low pressure and 1/2 oz high pressure. Good stuff with some crema. This must be my best espresso day :)
Arpi
Link to "Simulating a paddle shot"by vanboom on Fri Jul 03, 2009 11:16 am
I've been tinkering around with pre-infusion and my Silvia. What I do is leave the steam wand open, and then hit the brew switch. The pump ramps up and the steam wand acts as a pressure relief valve. Then by feel on the knob, I can tell how much pressure is in the system and fine-tune the relief valve nearly closed - i.e. pinch off the relief flow, which sends more flow to the grouphead. After about 10s, I close the valve fully and the extraction begins.
Rancilio Silvia Preinfusion Technique
--don
vanboom
Link to "Simulating a paddle shot"by denniskeating on Fri Jul 03, 2009 11:23 am
Hi Arpi, Have you tried boosting the line-in pressure? You will have to readjust the pumps bypass valve to your brew pressure. You should get faster preinfusion in mid lever position. Some folks go 25-35 lbs. inlet pressure. -Dennis
denniskeating
Next
Return to Tips and Techniques
