by Gus on Tue Jul 14, 2009 11:32 am
Maybe a title change is in order? Something more along the lines of "Experimenting with coffee using an espresso machine and grinder"
It seems to me this is no longer about simulating a paddle shot, and I'm not sure that it ever was. It seems that it is more about experimenting with coffee at brew pressures, extraction ratios, and grind particle sizes outside of the espresso range. You are certainly brewing coffee, but it does not appear to be espresso, and it is not a simulated paddle shot.
After reading this it seems like you started experimenting with line pressure preinfusion to compensate for uneven extraction starts. Apparently long low pressure preinfusion was not the complete answer to the uneven start issue because along the way you also looked at your dose / distribution technique. And finally you started pushing the grind further and further out of the espresso range ending at a drip grind. In the end you are completely outside of the espresso range and are moving into something more like brewing single serve drip coffee with your espresso machine.
What I would like to know is did any of these experiments help with your espresso, or are you just having fun experimenting with your equipment?
I already know that grind size affects the flavor. Particle size, and dose / distribution combine to set up the baseline of the extraction. I already know a change to any of these variables will affect the overall outcome and flavor in the cup. I already know the baseline combined with brewing parameters of pressure profile, brew temperature profile, and total extraction time / volume result in the final cup. A change to any of the brew parameters also changes the flavor. This does not even begin to scratch the number of total variables at play, it just represents the basics.
Please don't take this as me trying to tell you how to use your gear or how you should enjoy your coffee. It's yours you should do what ever you like. I am just curious what you are trying to learn from all of this and if there is anything new that applies to making espresso.
Gus
Insert catchy phrase of choice here
