Should a ristretto be properly extracted?
Sounds kind of ironic I know. I am aware there are many different ways people pull a "ristretto". I am of the camp that it's a tighter grind and longer pull yielding a lower ratio (I use Andys chart). Not my question here though.
Is the assumption that a ristretto should still be fully extracted (I.e. 20% EY as a reference)? I feel like the answer is yes. I can manage that with a 1.5 brew ratio. But how in the world can a 1-1 ratio (100% ratio) fully extract? Maybe it just takes a crazy fine grind and really long pull?
Is there something to be gained from, or is the intention to pull a ristretto less extracted? (I.E. 16% as reference)
- aecletec
Have you seen this idea?
http://www.jimseven.com/2010/11/08/the-double-hump/
"Properly" as 20% and "should" don't seem to be widely accepted, especially when different roasts are taken into account.
- TomC
An admittedly dumbed down answer is: If it tastes better that way, then yes. That's really the end goal. I don't believe baristas of days of old were doing this for anything other than the results in the cup. What EY resulted wasn't a known variable for most.RyanJE wrote: Is there something to be gained from, or is the intention to pull a ristretto less extracted? (I.E. 16% as reference)
In theory - the extraction yield should be the same for a ristretto, normale or a lungo.
EY is how much matter you have extracted from the coffee dose. Generally, this is a value calculated from a direct measurement of TDS (total dissolved solids) and beverage weight, per weight of dose.
For instance, you pull a 20g shot and use a refractometer and you measure 10% TDS. That means 2g of that shot is extracted coffee. Presuming the dose was 20g, you've extracted 2g of that dose into the cup and achieved an EY of 10%.
A well extracted shot should be 19.5% in an ideal world. So, of 20g dose of coffee, you'd need 3.9g of extraction into the cup.
Given a 20g dose:
Ristretto 1:1 ratio = 20g of beverage.
Normale 1:2 ratio = 40g of beverage.
Lungo 1:3 ratio = 60g of beverage.
Therefore:
Ristretto shot weighing 20g should contain 3.9g of extraction and measure 19.5% TDS and calculated extraction yield of 19.5%.
Normale shot weighing 40g should contain 3.9g of extraction and measure 9.75% TDS and calculated extraction yield of 19.5%.
Lungo shot weighing 60g should contain 3.9g of extraction and measure 6.5% TDS and calculated extraction yield of 19.5%.
Notice that "strength" is related directly to TDS. The ristretto is "stronger" and denser than a "lungo", because they both contain the same amount extracted materials in different volumes of water.
In reality, it is quite difficult to achieve extractions of this level in a small volume of water and ristrettos often come out sour because they are underextracted.
Perger's article on the subject is here:
https://baristahustle.com/blogs/barista ... ding-yield
Given a 20g dose:
Therefore:
I understand and certainly agree, I was just trying to put a frame of reference on what I was asking. I don't don't think only one EY is the right number, that was not what I was getting at.aecletec wrote:Have you seen this idea?
Of course the end game and what matters most is taste, this is more about creating a recipe. If a modern cafe were creating a recipe for a ristretto how do you think they would approach (regardless of ease of workflow for them). They want to serve the best tasting ristretto.TomC wrote:An admittedly dumbed down answer is: If it tastes better that way, then yes. That's really the end goal. I don't believe baristas of days of old were doing this for anything other than the results in the cup. What EY resulted wasn't a known variable for most.
Are they aiming for (try this different) an extraction that falls in line on the SCAA guide charts? Or something else?
- JohnB.
nuketopia wrote: In reality, it is quite difficult to achieve extractions of this level in a small volume of water and ristrettos often come out sour because they are underextracted.
Is that your experience or Perger's opinion? I don't conduct scientific experiments on my shots, I just drink them. I only drink Ristrettos, 3-4 a day & they don't come out sour. Quite the opposite really but then I'm not pulling shots with light (under?) roasted beans meant for other brew methods.
LMWDP 267
- Spitz.me
Correct me if I'm wrong, but you would have to increase grind size to get the "ideal" TDS in a ristretto which, may still make a ristretto by definition, but not the one that people seek. Unless science has also found that ideally all coffee is always extracted prior to the 100% mark for the ideal espresso recipe.
I'm with John, I have never tasted a sour ristretto. Sour normales happen regularly.
LMWDP #670
I read a lot of Perger posts etc. I have learned a lot from doing so. However, I don't understand why he says you cannot have an extracted ristretto. I have no problem extracting shots at 1.5 ratios. I just grind finer and pull longer. I can understand though why he states with increase in strength you lose some clarity.nuketopia wrote:In theory - the extraction yield should be the same for a ristretto, normale or a lungo.
Given a 20g dose:
Therefore:
