andrewpetre wrote:Be very very very wary of the thick crema espresso fantasy.
Unless your coffee out of the pressurized basket tastes bad to you, do nothing. Go back and use the machine as it was designed, and do nothing but clean it on schedule.
Do not disassemble; do not tinker. Make and drink coffee.
Andrew, real espresso from a depressurized pf (also known as a portafilter) is no fantasy. I use the Starbucks Barista every day with a non-pressurized portafilter with results that, while not in the same league as higher classed machines, is in every way within acceptable espresso paramaters. These results are also nothing new for Barista users, almost all of whom de-pressurize their pf's once they reach the "forum stage". While I reckon just about all of these users have upgraded (it is a low-end machine after all), I am quite certain that an internet search, or a simple search of this forum would bear me out that people who actually owned and used this machine recommend depressurizing the pf as one of the first steps in getting the most out of it. (And yes, the taste does suck from a pressurized pf, mainly because you need a coarse grind for it to work - a 30 second shot with a pressurized pf filled with drip grind coffee - mmmm).
Wayne, once you get a good grinder, and some fresh coffee, you will be pulling any kind of shots you want to pull. BTW, you
don't need to spend a fortune on a grinder. There are decent hand grinders that, while inconvenient, are certainly able to produce the kind of grinds you need.
