Shots are watery, pull too fast after cleaning
Postby gaggia1516 on Sat Apr 28, 2007 10:38 am
I seem to be having problems with my Gaggia Coffee De Luxe. I have had my machine for 4 months, everything was going fine until I cleaned the machine. Now all the shots I pull are a watery mess. I have changed the grind setting 3 times and nothing seems to help. The shots pull way too fast and it doesn't seem like I have the pressure I once had at the grouphead when I first bought the machine. Also, it seems my shots are channeling. Please help.
gaggia1516
Postby TimEggers on Sat Apr 28, 2007 10:43 am
Hello! Can you please specify exactly how you cleaned the machine? What type of cleaner(s) (and how much) did you use?
TimEggers
Postby gaggia1516 on Sat Apr 28, 2007 10:47 am
I used Cleancaf and let all of the parts soak in it for an hour. I also ran it through the boiler and the steam wand.
gaggia1516
Postby TimEggers on Sat Apr 28, 2007 1:07 pm
Can I assume that you have rinsed and flushed everything extensively?
TimEggers
Postby miKe mcKoffee on Sat Apr 28, 2007 1:19 pm
While it doesn't sound like the cause of shot problems, I'd also suggest removing and cleaning group screen and dispersion block above it as part of normal cleaning procedures.
Also too fast a shot and seemingly lower shot pressure seems opposite what low shot pressure would cause. And channeling problems. Assuming the screen is clear hate to say but sounds like the problem is at the handle side of the PF in consistent dose, distribution and tamp.
Mike McGinness, Head Bean (Owner/Roast Master)
http://www.CompassCoffeeRoasting.com
miKe mcKoffee
Return to Tips and Techniques
