Shot starts great, mouse tails, then gushing 12 seconds later
Postby srossnz on Mon Oct 18, 2010 5:58 pm
Hi, I bought a pocket scale to start measuring my dose and doing wdt. So i have a stock Silvia basket which they say is 16gms. I try 16gms and initially the shot looks superb.. it takes about 4 seconds to start, thick syrupy mouse tails appear, but after 10secs or so it all goes to crap with thick stream then watery. I examine the puck and it looks fine with no signs of channeling so I don't know what the deal is. If I grind finer or tamp harder the machine chokes. I just can't seem to get a 25sec pull on this thing, it is a 15sec nasty shot. I guess I will keep playing with dose, maybe 18gms? (coffee is fresh, roasted 3 days ago).
*update, ok made some adjustments. I tried 18gms and it near choked with 1 oz in 50 seconds. Tried 17.2 gms and i got a 22-25sec shot but just 1 oz.. Might try 17.5 gms and see if I can at least get a decent 1oz shot. hmm
srossnz
Postby Marc on Mon Oct 18, 2010 7:34 pm
It can be some channeling, it can be too high of a dose (but 16g seems really fair to me), It can be too hard of a tamp.
basically what's your machine is doing is finding the weakest link in your puck because it's too tight and the coffee can't be infuse slowly.
Marc
Postby Randy G. on Mon Oct 18, 2010 7:37 pm
Keep the dose constant and adjust the grind. Once you are close, then vary the dose and adjust grind accordingly to experiment with the most important judgment factor being taste.
Espresso! My Espresso!
Randy G.
Postby HB on Mon Oct 18, 2010 7:55 pm
Sounds like channeling. Don't bother looking at the puck, since any fractures you might observe are more likely to have been created by the 11 to 0 bar depressurization in less than a second than the leisurely pressure build up during the extraction. You should dose less too since prevailing advice is that the stock Silvia basket is too shallow for a 16 gram dose.
another_jim wrote:The Rocky is a much better grinder for low doses and fine grind than for higher doses and coarser grinds. The stock basket is fairly shallow, and the Silvia is much harder to use when the coffee is mashed against the shower screen.
For a beginner, this translates into nice shots after a few tries if you keep the dose low and consistent versus nice shots after a few hundred tries and after a few months if you insist on filling the basket to the rim.
This and other references found by searching on stock Silvia basket.
If you haven't already done so, you should lower the brew pressure. The stock Silvia is set to 11 bar. Lowering it to 8 bar will greatly increase your margin of error. Search a bit and you'll find numerous threads describing how to lower the brew pressure (and how to deal with not having an onboard brew pressure gauge). I believe the FAQs and Favorites links them too.
Postby cafeIKE on Mon Oct 18, 2010 7:56 pm
Keep tamp moderate as it's easier to be consistent.
'Coffee roasted 3 days ago' is no guarantee that the coffee is suitable for espresso unless that same coffee pulls great shots in a quality cafe.
Additionally, many great professionally roasted espresso coffees are not at their best until days 5,6,7,8...
cafeIKE
Postby srossnz on Mon Oct 18, 2010 9:45 pm
Thanks guys, I managed to get a solid 1oz good looking extraction but it tastes horrible. Even though I have reset my silvia to like 8.5-9bar and have a PID I am easily making the worst espresso in the world (I wonder if there is an award for that). I suspect I have no flippin idea what my temp should be set to.. even though the PID says 105 it's not 105 that is just what the top of the boiler is, so can anyone advise what type of device I can use to read temp out of the group so once and for all I can know what to set my PID to? When my PID is on 105 steam is frothing out of the head yet some guys were telling me to set it at 109c.
srossnz
Postby Bob_McBob on Mon Oct 18, 2010 10:12 pm
A bottomless portafilter would make a big difference in helping to diagnose your extraction issues.
Chris
LMWDP #295
Bob_McBob
Postby HB on Mon Oct 18, 2010 10:45 pm
srossnz wrote:When my PID is on 105 steam is frothing out of the head yet some guys were telling me to set it at 109c.
You could try dropping the temperature in 5C increments. Once you know you've passed into sour, hike the temperature halfway back to the last setting.
Postby srossnz on Tue Oct 19, 2010 6:12 pm
well checked my brew pressure and it was ok. I ran through more shots this morning going on someone stating 'do not dose more than 14gms in a stock silvia basket' -that was a total catastrophe.. i tried 5 different grind settings and tamping pressures and all i got was pucs so watery they stuck to the shower screen or looked like soup in the basket. I keep saying I am going to throw in the towel and get a home trainer to come by but have been putting it off due to finances. Looks like I'll have to bite the bullet because either I am completely hopeless or something is wrong with my kit, but nothing comes out of this thing other than nastiness. Even considering selling it and giving up on espresso all together.. i mean some people simply can't hit a golf ball straight no matter how much they practice so maybe the same is with espresso, some people just can't do it :/
srossnz
Postby cafeIKE on Tue Oct 19, 2010 6:27 pm
I've seen some Rocky grinders that can't grind fine enough for espresso. The symptoms are exactly as described
Have you checked burr zero?
cafeIKE
Next
Return to Tips and Techniques
