Settling grinds before tamping?
mbishop
#1: Post by mbishop »
Hi all,
I was having trouble with channeling and my grinder isn't great (lots of clumping) so I tried something to change the distribution of my grinds. It is similar to how when you buy a box of cereal, it says "package may not appear full as settling may have occurred". I decided to try "settling" my grinds in my portafilter before tamping.
What I did was to get one of those cork pads that you set plants on from the hardware store to use it as a pad off which I lightly "bounce" my grind-filled portafilter. I'll bounce it on the pad for about 15 seconds before I tamp but interestingly, by doing this, the grinds have settled almost to the level where I would want to tamp them anyway so it's a very light tamp, almost a simple polish.
Channeling seems rarer with this in place and I'm much happier! However, I'm new to this, so is this a known and obvious trick? Or am I unknowingly making my shot worse by doing so?
Best,
_ michael
Mark08859
#2: Post by Mark08859 »
The Orphan Espresso "Slap Shot" technique. It dates back to ~2009. I think they used to sell a tamp pad expressly for that purpose, but I don't know if it still exists.
cmin
#3: Post by cmin »
I have a tamping mat, forgot the kind, just a small rubber one with a placeholder for a tamper in it. I just do 1 or 2 quick taps and that's it though, not 15 seconds but whatever works for you. I WDT, tap or two, then tamp.
mbishop (original poster)
#4: Post by mbishop (original poster) »
Mark08859 wrote:The Orphan Espresso "Slap Shot" technique. It dates back to ~2009. I think they used to sell a tamp pad expressly for that purpose, but I don't know if it still exists.
And there it is. Nice! Thanks for sending that.
[creative nickname]
#5: Post by [creative nickname] »
Hockey pucks are great for this; hence the "slap shot." I do a few light taps to settle the grinds in MCAL baskets, and a much more vigorous and prolonged series of taps to prep Caravel shots, which taste best when the basket is loaded to full capacity.
LMWDP #435
cmin
#6: Post by cmin »
Here's what my mat looks like and can see the cut out for the tamper. Not sure who makes it, when I bought my machine the guy sent this with it.
edit - n/m, this site apparently doesn't allow offsite images (huh?!?!?), even tried href tags. Tried uploading the image and says it's larger then 2mb, give up
yakster
#7: Post by yakster »
I do this on a hockey puck.
-Chris
LMWDP # 272
olddogTim
#8: Post by olddogTim »
You should try a cheap aquarium air pump that is adjustable (the ones that vibrate) :P
Getting old STINKS, but it's better than not getting old! Tim
cannonfodder
#9: Post by cannonfodder »
Been doing that for years. I give the portafilter 3 light thumps on my tamping stand then tamp.
Randy G.
#10: Post by Randy G. »
I tap around the bottom edge of my bottomless PF with the top of an aluminum tamper, but the aquarium idea is very interesting.
Post Reply
