I'm writing because I wanted to share a solution I found to keep my portafilter basket from falling out every time I knock out the old grinds. I have two machines with these clipless portafilters, an Olympia Coffex and a La Pavoni Europiccola. The Coffex was bought off of eBay and performs beautifully. But the basket seemed permanently connected to the PF. When I finally pried it off with a screwdriver, I was able to clean away years if not decades of black residue using JoeGlo and a wire brush on a Dremel tool. But now there seemed no way to reattach the basket, and it would fly out if I even tilted it sideways.
I was just ready to spring (sorry) for a bottomless PF for the Coffex at $150 because that's all that's available with a spring clip when I thought to try adding a spacer between the basket and the PF just to make it a bit more snug. (I realize the benefits of a bottomless PF and use one on my E61 machine to work on technique.) My first thought was a rubber band, and I realized that could get nasty. Then I tried Teflon tape, the kind you get to secure the threads on a faucet, and voila! The basket stays put or it can be easily removed, and when it's time to give the PF another thorough cleaning, I'll simply replace the tape, which runs less than $1 at the hardware store.
I plan to use the same solution for the Europiccola.
