by JmanEspresso on Wed Apr 08, 2009 12:04 pm
I have found, for me, the most consistent way to use the Major, with hopper and doser attached, is as follows...
Weigh out beans for 1 double shot. Add to hopper. Grind while thwacking until all beans are ground and have been thwacked into PF. WDT/Level/Tamp/Lock&Load.
Making another shot/drink? Do it again.
If I weigh out the amount of 2 double shots, add them to the hopper, and EITHER, grind it all, dose PF, pull shot, dose again, pull again.. I get very different pulls. If I grind what I think is enough to one shot, pull that, then grind the rest..forget it.. I couldnt repeat the doses using this method if I wanted to
Conclusion? Grind per shot, only adding what you need to the grinder for that shot. If you want two shots, start the process over. For me.. this is the most consistent and easiest to repeat way of pulling shots of lovely espresso.
Try it out.. of course.. YMMV
Jeff
