Sea level to 2000 meters, extraction all wrong. - Page 3
Nick Name
#21: Post by Nick Name »
kiboker wrote:I don't know if you saw but there was no advice given.
I think there was, but maybe not as clearly stated as it could have been.
If you're coffee lacks the body, you'll have to change the ratio (and that is what I think Rapidcoffee was trying to point to you). Like it or not, most people on this forum define lungo by the ratio. Only old-school Italians do it by the volume (defining espresso shots by the volume is so pre WWII :wink: ). If you want to stick to that, you will have semantic problems in most discussions on this forum (or any other coffee forum).
To put it as simply as possible, try a tighter ratio. Maybe a ristretto (by 3rd wave standards, not by Italian standards). How does it affect your shots?
For further diagnostics this should be a useful read: https://baristahustle.com/blogs/barista ... so-compass
kiboker (original poster)
#22: Post by kiboker (original poster) replying to Nick Name »
Unfortunately, grinder any finer or higher dosage just yields unmanageably slow pulls north of a minute
DeGaulle
#23: Post by DeGaulle »
Given all of the above, I suggest you try and increase your dosing a bit, as far as allowed by the head space on the groiphead. Don't know your machine, but If it holds a commercial 58 mm portafilter, you might want to try a deeper basket like VST if the stock filter basket doesn't allow doses higher than 14-15 grams. If it doesn't give you the result you are looking for, try adjusting the pstat for a slightly higher brew temp as well.
Bert
Post Reply
