by cannonfodder on Fri Oct 17, 2008 6:34 am
The green bars are usually chromium oxide, white is often referred to as white rogue and the red is red rogue, whatever the name the key is the grit of the material and the composition of the grit, chromium, diamond, etc will all have different cutting power. A 3 micron diamond paste will cut faster than a 0.25 micron diamond paste but a 0.25 micron paste may cut faster than a 0.5 micron chromium oxide because of the grit medium.
When I am restoring antique blades I will work a grit progression from 400 wet/dry (depending on how bad the blade is) 800, 1000, 1500, 2000, 2500 then micromesh and finish with 1.0 micron chromium oxide, 0.5 micron CO, white rogue, polish to get that perfect mirror finish. But doing that on an espresso machine would be very time consuming and you need a buffing wheel with different disks for each compound.
