Scorched/burned pucks
Postby TomC on Fri Jun 24, 2011 1:07 pm
I always do a search before starting new inquiries and I couldn't find anything under scorched or burned in regards to the actual puck of spent coffee in my espresso. All the replies that came up referred to either a burned taste to the coffee or made mention of burned/scorched milk....
My espresso doesn't taste burned. But nearly all of my pucks have nearly blackened bands around them, usually on one side. Is this normal? I've not seen it mentioned here, so it makes me curious.
I am brand new to pulling my own espresso, so I am sticking to what general consensus tells me to do. I am 2lbs in to a 5lb bag of Redbird Espresso, with temps set on the Duetto II @ 198 at the brewhead. The temp seems to wander a bit from 196 sometimes up to 200, but I try and pull when it's reading right at 198-199 ( I don't know how precise the temp PID is on this unit). I dont flush the group pre-pull.
Fresh out of the roaster: SM Ethiopian Yirg Grade 1, Compass Ethiopian Sidama
Next batch: Guatemala Geisha...
TomC
Postby Javacat on Fri Jun 24, 2011 1:52 pm
Try setting your PID to 187 or 189. I never scaced my machine but this is the temp range that I found worked best when I had my Duetto II. My machines' offset was calibrated at Chris' Coffee, but for whatever reason, I nearly always had my best shots in this temperature range - anything above that seemed to scorch the coffee, and I played around with ALOT of coffees from Intelly, CC, Metropolis, Klatch, etc. See if that helps.
Javacat
Postby TomC on Fri Jun 24, 2011 2:03 pm
I appreciate any input, but specifically what I'm asking is, is this an aberrant phenomena? If the result in the cup tasted burned or off, then my answer would be obvious. But it's not. I've managed to pull some awesome shots rather consistently.
TomC
Postby HB on Fri Jun 24, 2011 2:12 pm
TomC wrote:My espresso doesn't taste burned. But nearly all of my pucks have nearly blackened bands around them, usually on one side.
Sound like residual water. Beyond consistently looking the same, I don't worry about puck appearance. Dry puck, wet puck, sandy puck... doesn't matter unless it changes from one extraction to the next.
Postby Randy G. on Fri Jun 24, 2011 3:10 pm
HB wrote:... I don't worry about puck appearance. Dry puck, wet puck, sandy puck... doesn't matter unless it changes from one extraction to the next.
Agreed. It's what is in the cup that counts... It's all that counts.
Espresso! My Espresso!
Randy G.
Postby TomC on Fri Jun 24, 2011 3:16 pm
HB wrote:Sound like residual water. Beyond consistently looking the same, I don't worry about puck appearance. Dry puck, wet puck, sandy puck... doesn't matter unless it changes from one extraction to the next.
Good to know. However, they are still black when the puck is bone dry the next day. Maybe fines migration to the bottom of the portafilter then? Either way, if it's not something to concern myself with, I'll turn my attention back to other matters :)
TomC
Return to Tips and Techniques
