www.baratza.com: skilled in the art of grinding
Same amount, same tamp pressure, but not the same results - Page 5
Postby cafeIKE on Sun Apr 05, 2009 8:14 pm
HB wrote:I feel confident asserting that compressed grounds have a greater density than uncompressed grounds. But if you disagree, please dry 20-30 spent pucks with clumps and 20-30 without, section them, weigh them, and report the results. Thanks. :)
You're just tryin' to get me to go away for a while and quit posting :P
Seriously, I've run that movie and there are massive technical difficulties in splitting the pucks to achieve any sort of meaningful results. If one sections the puck in a few segments, the clumps could average out. If one tries many segments, it's very difficult to maintain section integrity.
I'm not certain that clumps are more dense. While intuitively it seems correct, their ephemeral nature when touched raises doubts. It very well could be that clumps are less dense, allowing uneven extraction.
Going farther, I'm still not convinced that clumps per se deserve their bug-a-boo reputation. When using a coffee that clumps, if the distribution looks more or less uniform, a mash & go yields a fine shot. If I don't redistribute, by whatever means, on a thwacked clumpless off center distribution, the likelihood of a sub par shot increases.
cafeIKE
Postby timo888 on Sun Apr 05, 2009 10:19 pm
Psyd wrote:This prep technique is a great one for you, at your house, with your coffee, and your machinery. And as it works really great for you, I'm sure there is something in it.
The value in the pared-down technique is its core focus on dose and grind. Fundamentals.
timo888
Postby misterdoggy on Mon Apr 06, 2009 5:31 am
I have returned a little to my technique from before to get me thru these confusing times
I use the large 10oz cups and I know this may not be looked at as acceptable, but I put the sugar cube in the cup before pulling. Instead of counting 1, 2, etc, I just look at the relationship of how high the coffee level is to the cube and that is the mixture for me. For instance I know that the cube has to be well covered and Voila. Normally takes 16 seconds using a double basket filled with about 17g to arrive. Its before blonding, but plenty of Crema, then add Latte. Molto Buono !!
I mean if your system works, and tastes good, then it can only get better from there. :)
misterdoggy
Postby misterdoggy on Mon Apr 06, 2009 10:44 am
Just tried a bottomless portafilter.
First time I got a perfect pour with tiger stripe everything you could wish for :)
The I went back later and it was spritzing out in every direction all over the place on the machine all over the cup everywhere literally. 98% went in to the cup but the side angle spritzing what's that all about.
I think I put a little less in the basked the second and third times, but otherwise I need to pay attention to what I did different.
The main difference is the size of the portafilter seems wider but less high.
misterdoggy
Postby malachi on Mon Apr 06, 2009 11:45 am
timo888 wrote:3. Each day, as your roast ages, you may have to grind slightly finer.
Not guaranteed to give best results. Past a certain point, with many coffees you'll have better luck going coarser and increasing dose instead.
malachi
Postby malachi on Mon Apr 06, 2009 11:53 am
Randy G. wrote:...
I got home and put together a blend similar to what I had been using with the other supplier's beans. This "new" bland was, iirc, 50% Brazil, 25% Bolivian, and about 25% Kenyan....
The new coffee is of a higher quality and, more importantly, fresher. The new source takes his coffee very seriously, actually going to South and Central America, visiting farms and farmers. He also cups the coffee and is particular about what he buys. The old supplier got quality coffee, but was more interested in the price than getting top-notch coffee. The result was much of his coffee was older...
This is an important point.
One coffee from Brazil and even one pulped natural from Brazil and even one pulped natural from Sul de Minas in Brazil is not the same as another.
The differences between coffees from two different producers in the same region of the same country - even if they are processed in the same manner, grown from the same cultivar and from the same harvest - are very significant. So significant, in fact, that assuming that they're going to act the same much less taste the same is foolish.
If I were to say, "I had a blend that was 50% latin coffee and 50% african coffee where I sourced the beans from a local roaster but when I tried the same blend with beans from Sweet Marias" everyone would point out that a 50% washed Colombian 50% natural sidamo is VERY different from a 50% pulped natural brazil 50% washed kenyan.
The exact same is true within a country and within a region.
So the real issue here is that you had an entirely different coffee and were assuming that you could pull it using the same parameters as you had with the previous coffee.
malachi
Postby malachi on Mon Apr 06, 2009 11:54 am
Psyd wrote:I've learned quite a bit from puckology.
And thousands and thousands of people said the same thing about reading entrails.
malachi
Postby malachi on Mon Apr 06, 2009 11:56 am
misterdoggy wrote:Just tried a bottomless portafilter.
The single best thing about a naked portafilter is that it exposes your issues with consistency.
That's what happened to you - and it's what's causing your travails.
You need to be consistent - in everything.
Break the process down into parts.
Do each part the same way, in the same sequence, with the same output - every time.
malachi
Postby misterdoggy on Mon Apr 06, 2009 5:43 pm
Thanks, I am going to try the Yogurt cup and mix up the grains and see how that goes.
What a mess when the coffee was spritzing all over the place. But also what a pleasure it was
to see it working just right with tiger stripping and all. Just when I thought I was there boom spritz....
I need some time alone with the machine and about a 1lb of coffee to just repeat repeat repeat
misterdoggy
Postby malachi on Mon Apr 06, 2009 5:51 pm
You need to be consistent on dose also.
A plastic yogurt cup won't help with that.
You need to have consistent weight or volume shot to shot. If weight, the max variance is 0.3g (with a target variance of 0.1g).
This is really important (in fact, far more important than other things - like tamp for example).
My suspicion is that your inconsistency in dose is very high and that and a high degree of inconsistency in distribution/bedding is causing MUCH of your struggle
malachi
PreviousNext
Return to Tips and Techniques
