Italyhound wrote:There is not much time to pour art into a macchiato cup I realize so holding the pitcher higher means you have to go really fast I suspect.
No, if anything, I'd say you need to try to slow the process down. Otherwise you'll overflow the cup. (Don't ask me how I know that.) Your speed and movements need to be proportionate to the size of the cup.
Italyhound wrote:I assume keeping the pitcher up is a way to compensate for less than adequate microfoam.
This helps with microfoam that's too thick, yes. If it's too thin, I'd suggest lowering the pitcher.
Italyhound wrote: have seen more often than not that baristas allow the pitcher to rest - still on the counter - prior to pouring art. What is the basis for this - it seems counterintuitive - as you spent your time essentially emulsifying air and milk and then you let it start to unravel.
Letting the milk sit too long, actually makes it thicker. I read somewhere that the milk should rest for around 10 seconds, but no more than 20, before pouring. Again, I think that's a means of compensating.
Italyhound wrote:I got pretty good at latte art with my Vivaldi 2 but when I switched to the 4 hole tip I have never recovered the 'knack'.
I'm curious why you switched tips if you were getting better results initially. Why not switch back?
