So at least on my machine, it seems that the zero point when "loaded" (that is, when actually grinding coffee) is different from the unloaded zero. This would indicate some play in the threading of the burr carrier (i.e. the force of grinding coffee pushing the burr carrier upward as the threading allows?).
Hmmm, interesting point. As I said before, my "0" point (when I can hear the burrs touching when there are no beans in the hopper) is 4, so I grind on 5 and obviously the grind is not fine enough. I was really afraid to try grinding on 4 or even less as I didn't want to destroy the burrs. And now tou are saying I shoud go beyond the "0" point?! If my "0" point was let's say 8 they I might try going lower but going to 4 or less seems to me too 'cruel' for the grinder... Is it possible to damage the burrs this way?
Also, is there a difference when you throw the beans into the hopper before vs. while the grinder is tuned on? Or is there a difference if you throw in just a scoop or two of beans vs. if the hopper is full of beans?
I know I'm getting paranid but could the grinder be defective? I'm almost sure the coffee machine is perfectly OK since I was able to get good extractino time with ground coffee from the coffee shop (originally they dialed it too fine and I was able to choke my machine!).
Thanks for more ideas or thoughts (or directing me to posts dealing with similar problems esp. with the Rocky+Gaggia combo)
