Recommendations on cleaning polished stainless steel espresso machine
Postby javacrazed on Wed Aug 18, 2010 5:48 pm
Questions keep coming...
I was wondering what the members would recommend to keep the Polished stainless steel outer shell of my ECM/Rocket shiny.
thanks again...
javacrazed
Postby Nik on Wed Aug 18, 2010 6:07 pm
I like this product;
http://www.barkeepersfriend.com/about.html
It comes in both liquid and powder form. I have never used the powder but the liquid is excellent. It is also fantastic for SS pots that are badly stained.
I bought mine at Surla Table but I think Lowes may have it as well. It's only $4-5.
Check this out!
Polish, Sealer, and Wax - 1st-line's own espresso machine polish!
Nik
Postby cannonfodder on Thu Aug 19, 2010 9:55 am
1st-Line carries a new polish just for machines.
I give my machine a wipe with a microfiber cloth every week when I do my cleaning. Keeps it in good shape but I did take my buffing wheels to it once for a mirror shine polish. MAAS is also a good metal polish.
cannonfodder
Postby Phaelon56 on Thu Aug 19, 2010 10:36 am
Barkeeper's Friend is fantastic. Highly recommended.
Phaelon56
Postby earlgrey_44 on Thu Aug 19, 2010 10:48 am
Nik wrote:I like this product;
I like BKF too and use it on SS pots and pans all the time. It's good at cutting cooked-on oil.
I'd be afraid to use the powder on a polished case though - seems like overkill when your main problems are water streaks and coffee splatter. I'd think it's too abrasive.
Perhaps the liquid (haven't used it) is less so than the powder?
Other advice:
Exterior Cleaning Tips
Cleaning Stainless Steel
earlgrey_44
Postby JohnB. on Thu Aug 19, 2010 11:21 am
Bar Keepers Friend is a non abrasive cleanser that uses a plant based acid to remove stains, rust, ect.
LMWDP 267
JohnB.
Postby Phaelon56 on Thu Aug 19, 2010 11:48 am
John's on the money - looks like an abrasive scouring powder akin to Comet, but it's not. The powder dissolves in the applied moisture, works very nicely and does a terrific job with the splattered on stuff. My Isomac is about a foot or so distant from the biggest and most heavily used burner on my gas range. I get lots of junk on the side of the machine but it comes off easily with BK.
Phaelon56
Postby earlgrey_44 on Thu Aug 19, 2010 1:32 pm
Phaelon56 wrote:John's on the money - looks like an abrasive scouring powder akin to Comet, but it's not.
Yes, definitely not as abrasive as a "scouring powder".
Sounds like an appropriate use - good to know. I think it's good to add the caveat that a light hand is advisable. There's a difference between "non-abrasive" and "no abrasive", and if you get too enthusiastic, I guarantee you can put microscratches on the surface with the powder. I once used it on a cotton cloth to clean an old chromed-copper toaster and I blew through the chrome right down to the copper before I knew it - doh! :oops:
So, I learned not to be too much of a muscle man with this stuff on a nice surface.
earlgrey_44
Postby David R. on Thu Aug 19, 2010 4:41 pm
I like Barkeeper's Friend, but its abrasives are insoluble; the active ingredient is oxalic acid. See the MSDS.
Our All-Clad polished stainless pots came with a recommendation for Bon Ami, and we have used used that for many years both on those pots and on other polished products with no evidence of scratches or swirls. Form it into a wet paste on a damp cloth or paper towel and gently rub on the steel.
David R.
David R.
Postby keepitsimple on Thu Aug 19, 2010 4:48 pm
Barkeepers friend is brilliant stuff - but - on the container mine comes in (the powder version) - it states specifically "do not use on mirror polished stainless steel".
Perhaps the stuff we get over here is different.
"Peek" is very good and usable on loads of different metals and surfaces.
Have a look at http://www.tripeek.com/productsusa.html
keepitsimple
Next
Return to Tips and Techniques
