Reasons for channeling
Postby Canuck on Wed May 30, 2007 3:48 pm
Unfortunately I don't have a bottomless PF or a digital camera to post a video here, but I think my shots have been channeling lately and wanted to ask if the machine could be a reason for channeling?
First some details
- I dose/distribute/tamp into the basket and use the WDT; the basket is not in the PF
- each time I tamp and put the basket in the PF, I'm sure it goes in differently (by that I mean if the basket had markings like a clock, the 6 would not always be pointed to the PF handle
- when I remove the PF after a shot, a 'dent' always appears in the same area (about 2 or 3 o'clock), the dent starts at the edge and moves inward for maybe 10mm, and is only a few mm deep, otherwise the puck is nice and solid
- the resulting shot tastes fine to me, but I've yet to experience a puck without this dent
So, can it have something to do with the machine (showerscreen, position of the machine, etc.)?
Anything I can diagnose and maybe correct?
I have a Brasilia club and Rocky DL.
Thanks.
Canuck
Postby jesawdy on Wed May 30, 2007 4:50 pm
Hmm, I would suspect the shower screen or water jet breaker if it has one.... have you had the shower screen out to have a look?
EDIT: How does the water stream look with the PF removed? Are you backflushing (water only and/or cleaner and water)?
Jeff Sawdy
jesawdy
Postby Canuck on Wed May 30, 2007 7:53 pm
jesawdy wrote:Hmm, I would suspect the shower screen or water jet breaker if it has one.... have you had the shower screen out to have a look?
The part of the group that I can't remove has 5 or 6 holes, then there is a heavy brass screen with 5 holes and a regular shower screen with many tine holes. I'm not sure what a water jet breaker is.
From day one I had them out and soaked them in Cafiza. I've done water only and with cleaner flushes.
I find the water comes out a little stronger on the right (3 o'clock) side, even after a thorough cleaning.
Today I ran a 2 second flush right before locking in the PF and when I removed it later it was an almost perfect puck...just a little dip in that side of the puck...but not as deep as usual. Shot poured nice and tasted great.
Canuck
Postby HB on Wed May 30, 2007 8:52 pm
Canuck wrote:...I think my shots have been channeling lately and wanted to ask if the machine could be a reason for channeling?
I'm not an advocate of puckology. Apart from the divot, what makes you think there's channeling?
Postby Canuck on Thu May 31, 2007 8:21 am
HB wrote:I'm not an advocate of puckology. Apart from the divot, what makes you think there's channeling?
If I never looked at the puck I wouldn't of mentioned it...really no other reason.
Sometimes I think the pour from my double-spout isn't 'perfect', but then I happen to come across videos here or on youtube (I was searching yesterday for videos of extractions from double-spouts), and I came across some from machines like the Brewtus or Livia, and my pours look equal/better, so maybe I'm over analyzing.
Thanks though.
Canuck
Postby HB on Thu May 31, 2007 8:42 pm
Canuck wrote:...I came across some from machines like the Brewtus or Livia, and my pours look equal/better, so maybe I'm over analyzing.
Perhaps. On the other hand, instead of "eye cupping" the pour, I recommend practicing to discern channeling by taste. Jim's Working the shot maps the taste characteristics and flow time:
An extraction suffering from channeling will be unbalanced towards the latter half: Bland, nondescript, initial sourness with mildly bitter finish. You can intentionally exaggerate this taste difference by dividing the shot into thirds and sampling the last two.
Return to Tips and Techniques
