Im no expert, but heres my thoughts,
The video seems to show some decent channeling, almost like the extraction doesnt fully develop until mid-way through the shot. The pictures on the other hand, look pretty solid.
Tell ya what Id do. If I was dialing in a new batch/bag of beans, and I pulled the shot you did in your video, I would loosen up the grind a little. Maybe a half-notch on Mr. Major. Keep the dose the same.
WDT. Cant advocate this technique enough. True, the major needs no help in de-clumping..it does a great job. The wdt is more-so about a perfect, evenly extracted shot, every...single...time. I use it for every shot I pull, and I RARELY see any clumps in the PF. Try it out, Im near 100% positive that will solve the channeling. Since you want the shots to be less bitter, you're going to want to end the shots at a max-time of 35 seconds. Ristrettos are a whole different monster, ones which can run sometimes 50seconds even. Shoot for 30 seconds, and roughly 1.5oz in the cup, more is cool, you dont want much less. Once you are happy with your regular, normale shots, then you can venture into ristretto-land.
Once you're getting shots that pour correctly, dont channel, and give you the right volume, then you can fool around with the temperature, keeping whats in the PF the SAME. Pro-HBs tell us that we should only change ONE variable at a time, so we can accurately diagnose any problems..this is great advice. IF you want to go up a degree, or down a degree, continue to dose 16 grams, WDT, and extract ~1.5oz in 30seconds.
Though, from the video, I really dont think temperature has much to do with the bitterness you describe in the cup. I really think it is from both, channeling as well as the shot running long. I am pretty confident that if you loosen up the grind, and use the WDT method on all your shots, you will be pulling espressoporn worth shots, every pull, and more importantly, your shots will be smooth as butter, sweet as cream, and deep as willy wonka's greatest creation. If you find that they are pulling correctly, no channels, correct time, and you still have bitterness that is unpleasant to your taste, then switch blends. Maybe take a break from your home blends for espresso and order from the pros for a little while. Pro-roast are spot on, everytime, so you dont have to worry about that variable too. As for tasting distinct notes, like floral, citrus, spice, etc etc, dont worry if you dont taste them fully there. Tasting all the notes in an espresso is as much an art as pulling the shot, and for me, if I can taste, say two flavors that arent chocolate and roast-flavor, Im a happy barista
And most importantly, just have fun. Espresso at home can get frustrating, and when it does, its time to change something. I recently got frustrated with my shots not tasting consistent from batch to batch, off flavors I didnt want, things like that. SO.. Im taking a break from home roasting for espresso for a while, and only pulling shots with pro-roast for the next month or so. My point is, you shouldn't be battling with your equipment everyday just to get that perfect shot.. you should enjoy the journey, both the good shots, and the not so good shots. Because at the end of the day, its coffee..and if you cant just enjoy your coffee, life is that much more of a pain..and thats something I think we can ALL agree on.
Good luck, let us know how things go!
All the best,
Jeff
