by JmanEspresso on Mon May 18, 2009 11:06 am
I just came to the computer from my machine, tested some things out. We have a similar setup, a mazzer and a vibe pump e-61.. but its not the same stuff.. and im no pro.. so take it for what its worth..
I find I'm able to be more consistent with a heavier tamp, so my grind is set to allow a 40ishLB Tamp.. With a couple different doses, I found the following..
First the setup:
Anita
M Major
Ridgeless double basket, LM style from EPNW, dosed IN the portafilter
Convex tamper
Boiler set at 1.1Max, Brew set at 9.5 on machines gauge.
Coffee is Counter Culture Rustico
With a 14 gr dose- Had a hard time getting a good shot here.. not enough coffee was my diagnoses
w/ a 15-gr dose- Similar to the 14.. not enough coffee to fully expand to the screen.
---Had very soupy pucks on both of these doses--- Had some channeling.. but mostly donut extractions with some squirts
Now here is where it gets weird....
16gr dose- Had a good extraction, no donuts, and it ran a tad longer then yours in the video. There was some pretty noticeable movement, or 'dancing' of the cone, leading me to believe, channels were a' lurkin.
---But the puck.. Looked almost identical to your picture. If this thread didn't exist, I would suspect lateral channeling---
17gr dose- A better shot then 16, blonded later then the 16. No channels, no donuts. A nice shot
18gr dose- too much coffee. Short of being 100% positive, I believe the puck cracked on the screen, which led to the massive channeling and squirting all over the back of my machine.
Conclusion- 17grs was the best dose for today with the Rustico.. Nothing new, 17 is what Ive used for Espresso Rustico whenever Ive had it.
But the thing I found most odd.. was at 16grs, I got a puck looking exactly like the picture.. an extraction that was pretty decent, with the only sign of channeling being a dancing cone. AND.. Out of all the shots I pulled(minus the 14/15gr shots) it was easily the one with most 'harsh' taste... I didn't think it was terrible, but If I was making my morning shots, I would have tried again.
So... couple things. I say try a heavier dose.. Pretty much every coffee I can get 17.5 grams in the basket, being careful to lock it in. Also, maybe try a different basket.. When I switched to the LM style, double ridgeless, I noticed easier consistency in my shots. And lastly, I would stay away from the SO's if you are finding a harsh taste. SO shots can be some of the hardest shots to pull.. Ive gone through two pounds of a kenya before I realized its potential as a shot. I would highly suggest some "signature" blends from roasters.. Like Toscano from CCC, Belle from Klatch, Ambrosia from Fresco, Black Cat from Intelly.
The recent 'discovery' of a possible water problem is DEFINITELY something to look into. Espresso is made from two things. And there is more water the coffee in the cup. Try a simple test... Take some of the same water you put in the machine.. and put it in a pot and bring it to a boil..let it cool, and taste it. that might give you some insight as to whether or not the machine is tainting the water, or its the water itself.
Also.. Gorilla coffee, per the website, is a darker roasted coffee. They boast about being a BOLD coffee. This can be good or bad, but if you are finding it harsh, try something lighter. Toscano and Belle are both pretty sweet, and forgiving.
Lastly, I know how frustrating it can be to have all this money into a hobby, all this knowledge available.. but when your at the group, the shots dont taste how you want them too. Its okay.. at the end of the day, it IS just coffee, and certainly not the end of the world. With that said.. Try a larger dose, stay away from the pickier SO shots and pull with sweeter, lighter blends, test our your water as I suggested, and most importantly.. Dont give up. You have a great setup, and certainly the potential to create amazing espresso... It WILL happen.
Good luck my friend.. I hope what I have said helps you, or at the very least, someone, in some way. Enjoy the day, enjoy the people, and enjoy the coffee.
Jman
